Huge power loss after cleaning - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 08-21-2012, 04:57 PM Thread Starter
Nak
Nak's Avatar
Hello all,
I had a buddy work on my bike. I have a 2001 750 Vulcan. He said the jets were clogged and I have leaks in both exhaust pipes at the gaskets. He cleaned the jets, tightened the exhaust pipes (still need gaskets will get them soon). After doing all that the power loss from when I first brought it to him is huge. On a moderate up hill i can hardly hit 55 mph. He checked the carb and everything seems to be in order (fuel, cable, vacuum synchronized the carbs, serviced the air cleaner, idles great, starts fine), so now we are at a loss. We both start school and are taking a break from the bike for now but we are fresh out of ideas. Thank you for any and all help.
P.S. I believe my bike is degoated because there is no converter and both pipes are on the same side.
Nak is offline
post #2 of 7 (permalink) Old 08-21-2012, 05:29 PM
Sounds like he routed a vacuum line wrong. Check the vent line going into the back of the right airbox that it's not bottomed out. (cut the end at an angle to prevent this)
post #3 of 7 (permalink) Old 08-21-2012, 07:42 PM Thread Starter
Nak
Nak's Avatar
I looked and plugged it in. Now I have a top end power issue. From 4k on it is gutless. Can that be caused by lack of back pressure (due to blown manifold gaskets)?
Thank you for your help
Nak is offline
post #4 of 7 (permalink) Old 08-21-2012, 08:03 PM
Umm YEAAAA... especially since you are running aftermarket pipes.
post #5 of 7 (permalink) Old 08-21-2012, 08:24 PM Thread Starter
Nak
Nak's Avatar
Ok, I will be ordering the parts soon (school starts). But if you can check the link and make sure we are all on the same page. the Part Number is 11060-1119.
Nak is offline
post #6 of 7 (permalink) Old 08-21-2012, 09:01 PM
That them
post #7 of 7 (permalink) Old 08-21-2012, 09:02 PM Thread Starter
Nak
Nak's Avatar
That them
Thank a ton. I will let you all know how it turns out.
Nak is offline
