Looking for 138 Main Jets. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 08-20-2012, 10:21 PM Thread Starter
Don't hate me, carb issues. lol
So I've been dealing with the carbs not being quite right for a while.
She is shaved with the mono filter under the tank. Not Pods.
Idle to almost 3/4 has good pull but as soon as I get at & above 3/4 throttle it bogs down & I loose power.
The main is a #140. I tried a slightly richer main & I got no difference so I'm looking to go smaller to try that.
So, I'm looking for a set of #138's. The stock ones are too lean. (132) Obviously.
So, if you have a set your not using & looking to find them a good home or want to swap for a set of 140's, let me know.
I'm also open for suggestions as "carbs" definitely are not my thing.
post #2 of 12 (permalink) Old 08-20-2012, 11:37 PM
Youngster
1stVulcan's Avatar
I thought 138's were stock...?
I just rejetted my carbs for the ear shave and took out 138's and 38's. One of the 4 got slightly worn on the top because it was stuck in the carb pretty well. Don't have them in front of me right now, but I can show pics and tell u which one tomorrow afternoon. If mine are 138's I'd be happy to send them along to you, as I shouldn't need them anymore. Just cover shipping for me and they're yours!
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
post #3 of 12 (permalink) Old 08-21-2012, 12:39 AM
knees in the breeze!!!
Tofer76's Avatar
stock i think is 132main /38 slow thats what i pulled out of mine
but i have some jets sitting here not used (too bad i cant return them to pj's since i didnt need them)
mains i have
132
138
150
158 but im not sure they are for the vn(was a mix up at pj's on my order)
pilots
38
40
http://map.vulcan750.net/
VROC# 33976
1994 VN750
MODS SO FAR:
honda shadow 750 sissybar
ear shaved, K&N pods
142/42 jets, Cobra pipes
oversized tires, vn800 seat
vn750 rad cover, Tank bib
custom mirrors, gel battery
Tofer76 is offline
post #4 of 12 (permalink) Old 08-21-2012, 01:31 AM Thread Starter
Yeah, 132 were in mine & that's what's listed in the repair manual as stock too. So, 1stVulcan, if you have 138 mains, I'd be happy to pay shipping.
But, I'm going to check on something tomorrow. (I thought of this after I posted) I've been doing a lot of reading about the carbs & jest & such & it turns out several Harleys use similar keihin carbs as our bikes.
I'm going to check their parts dept tomorrow as I've given up on my local Kaw dealer.
Their Worthless!
post #5 of 12 (permalink) Old 08-21-2012, 08:50 AM
Crap, I WAS in 5th gear.
You could try running it without the filter- if it improves you are on the right track with smaller jets
Kelly2001 is offline
post #6 of 12 (permalink) Old 08-21-2012, 09:43 AM
you sir are correct... Ron/Lance used to sell us Harley Jets...
post #7 of 12 (permalink) Old 08-21-2012, 04:45 PM
Youngster
1stVulcan's Avatar
I've gotten parts from the local harley dealer for our bikes a couple times. They actually had the brass elbow for the fuel lines on our carbs for $11.
And sorry Kanuck69 I've got 132's and 38's. I knew one of them was a 38...
At ~20,000
post #8 of 12 (permalink) Old 08-21-2012, 05:42 PM Thread Starter
Hey, No problem. thanks for checking. I'm hoping to get lucky after work!
post #9 of 12 (permalink) Old 08-21-2012, 06:32 PM
I think I have an extra set of 138's. I will check my stash later.
TSmith68 is offline
post #10 of 12 (permalink) Old 08-22-2012, 08:21 AM Thread Starter
Cool, let me know. I have one more local spot to try, then I'm out of luck locally.
