recently had boots between the carb and intake replaced(not leaking-sucking air I checked) had the throttle cable replaced,new air filters and plugs.When i got it back from the dealership i noticed when i hit a hill my RPMS stay the same but the speed drops off, if i pull the throttle all the way back i don't gain speed and at 65MPH on a small hill i have to drop to 3rd from 5th to get back up to speed.compression:170 lb.s,carbs sych'd no issues found.HELP!!!!!
throttle feels sluggish on response.they also serviced the carbs.Kaw dealership no help.
Sponsored Links | |||
Any chance the clutch is slipping?
Absolutely x2 ......simple cable adjustment (if that is the problem).
WilliamTech
WilliamTech
Make sure the vent line to the right ear is not bottomed out. ( most cut the end at a 45 degree angle to prevent this.
Are you sure both cylnders are firing?
Is there any unusual noise?
Do make sure the throttle is opening the throttle valves all the way.
Originally Posted by WilliamTech
View Post
WilliamTech
WilliamTech
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
