Just cleaned car, doesn't start now - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 08-04-2012, 09:10 PM Thread Starter
Just took the carb out to clean it and put everything back on. Now the bike won't start and there's no fuel coming out of the tank. I have an inline fuel filter so I can see that no gas is coming out.
numb0617 is offline
post #2 of 6 (permalink) Old 08-04-2012, 09:16 PM
Are you sure the lines to the Petcock are properly connected ? ?
The petcock will not allow fuel to flow w/o Vacuum ! (center connection to left carb vacuum port).
hope this helps
Williamtech
post #3 of 6 (permalink) Old 08-04-2012, 09:18 PM
romeobravo172
romeobravo172's Avatar
What WT said!!! ck that out, no vac no gas!!!
romeobravo172 is offline
post #4 of 6 (permalink) Old 08-04-2012, 09:35 PM
Also checkthat petcck is set to run.
post #5 of 6 (permalink) Old 08-05-2012, 03:05 PM
Even if the petcock is set to run, you still will need vacuum to the petcock to get gas to flow to the carbs.
Early 700's and 750's had a setting for prime to fill the carbs, then you could turn it to run once the carbs had gas.
TSmith68 is offline
post #6 of 6 (permalink) Old 08-06-2012, 02:31 PM
Cheman's Avatar
If cleaning your car can keep your motorcycle from starting, I'm gonna have the dirtiest car in the world. Maybe I already do
Che
1986
Purchased 7/03 w/13000 mi
Sold10/10 27,000miles
Ear shave
V&H Cruisers
Tim Parrott stator
Iridium Plugs
AGM Battery
Splines lubed
Clear Alternative LED brake light
TOC mcct
Mutazu LN Hard saddlebags
Chad's floorboards
Current ride-2009 Honda VTX1300
Cheman is offline
