help with gas tank - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 08-02-2012, 07:20 PM Thread Starter
help with gas tank
i have a 99 vulcan 750....i have the service manual and attached a pic of the side bolts that mount to the frame.
the problem i am having is on the left side. i turn the bolt to tighten or loosen and it just spins away doing nothing. I can feel inside the frame and whatever the bolt is connected to is not spinning so even if i can get into this super small area with a wrench, there is nothing to hold on to that will allow me to tighten or loosen this bolt.
ideally i would like to tighten this thing up. But my thought was to take it apart to see if the rubber is still good. The problem is that i cant remove or tighten this bolt what so ever.
i dont even want to ride the bike with the amount of rattling i am hearing from the tank...its beyond annoying. The right side bolt seems tight enough and the 1 under the seat is fine also
any help would be great...thanks!
mike19 is offline
post #2 of 2 (permalink) Old 08-02-2012, 07:31 PM
Makes me believe the "Metric" Threads are stripped. My solution would be attach a pair of "Vise-Grips" and have a Tug of War while turning CCW.
hope this helps
WilliamTech
