Throttle cable strings - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-31-2012, 12:51 AM Thread Starter
I am referring to the springs that run along side the cylinder head and behind the right ear for the throttle cables.
I am considering cutting them off. For one, I believe they are vibrating against the back side of the ear and the cylinder head. It is incredibly annoying. They vibrate worse at around 3500 to 4500 RPM's. I need to do something, the noise is driving me batty! Really sounds like something is wrong, but I can't find anything loose externally and the motor is performing fine.
Any other ideas would be helpful. Thanks.
EDIT: Holy fumbling fingers, Batman! I meant "Springs" in the title, not strings! LOL!
post #2 of 10 (permalink) Old 07-31-2012, 01:08 AM
Suggest balancing your carbs.....that may be the culpret !
WilliamTech
post #3 of 10 (permalink) Old 07-31-2012, 01:14 AM
romeobravo172
romeobravo172's Avatar
WT--balance the carbs? Explain more please!
romeobravo172 is offline
post #4 of 10 (permalink) Old 07-31-2012, 01:30 AM
Balancing the carb's often reduces vibrations created within our engines.
I stopped my lic. plate from further cracking /falling off via a Carb Balance.
It is a process of equalizing the vacuum between the two carb
's at idle. Can be done for $5.00 or less. There are a few verse's on "How to"..
.. check it out.
hope this helps
WilliamTech
post #5 of 10 (permalink) Old 07-31-2012, 01:32 AM
romeobravo172
I think before I cut them off I would try to isolate them from any rubbing or vibrating, like maybe taping them to ear to see if that is the prob. Think they serve as a heat shield as they run right against the head. You mentioned the rpm's and that caught my eye! When was the last time you had your tank off? And are you sure the rubber cushions inside the bolt wings are there or are in the right place?
post #6 of 10 (permalink) Old 07-31-2012, 01:37 AM
romeobravo172
WT, Thanks, did not know that carbs out of balance would cause vibration. That has been on my short list of things to do for a while. Wanted to ck that just to make sure they were in sinc, will def do it soon. Thanks
post #7 of 10 (permalink) Old 07-31-2012, 01:38 AM Thread Starter
I have never had the tank off. I'm gonna look around some more tomorrow. The tank is nearly full with gas. I'll wait to remove it when it has less.
post #8 of 10 (permalink) Old 07-31-2012, 01:46 AM
x2 !
WilliamTech
post #9 of 10 (permalink) Old 07-31-2012, 01:55 AM
romeobravo172
I brought that up because not long ago I bought a 2nd 04 (have since sold it) and at about those rpm's it had this STRANGE rubbing squeal kind of noise, really weird kind of hard to explain it. Really had me concerned for a day or two. One day when it happened for what ever reason I put my hand on the tank and it stopped! Started to trace it down and figured real quick that the PO had the tank off and more than likely had droped the rubber cuhsions out of the inside of the attachment wings, very common they fall into what I call never land!! Anyway, he did put some kind of bushings but put them on the outside of the wings, not the inside!!! Is a wonder he did not crack the tank!! Actually did find both of them down in never land (dark places like fan shroud, and one was actually inside the top back indent in right ear!) Anyway that sound was the tank. My advise to anyone pulling tank is to take a minute and glue those rubber pieces in so they cant fall out on install!
post #10 of 10 (permalink) Old 07-31-2012, 06:33 AM
Ndr
Just flip the petcock to off, disconnect the hoses and fuel gage wire. take out the 3 bolts and lift her off. Easy Peasy. No need to wait on an empty tank. I like to bunch up an old rag and put it under the petcock when I put the tank on the table/bench to help avoid damage as well as soak up any potential leakage.
Ndr is offline
