Ear shave issue, defeated!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 41 (permalink) Old 07-21-2012, 07:09 PM Thread Starter
vn700rider74's Avatar
Exclamation Ear shave issue, defeated!!!
did an earshave and now bike sits and idles pretty good and opened up runs fine. Problem is when taking off it sputters and when coming to stop or let off the throttle with clutch pulled it tries to die or does die. I'm running 142/42's with K&N's. Could this be caused from the vent tube being in the frame tubing that is connected to neck that the 2 tubes branch off of under tank? It is facing forward but I figured the neck and everything else would prevent wind enough.
vn700rider74 is offline
post #2 of 41 (permalink) Old 07-21-2012, 07:12 PM Thread Starter
This is pretty much what it was doing before shave that led to redoing the whole bike.
post #3 of 41 (permalink) Old 07-21-2012, 07:27 PM
I'm guessing when coming to a stop, if you fiddle with the throttle for a bit you can get it to idle? Have you tried backing the pilot screws out another 1/2 turn? While you had the carbs out to jet, did you give them a cleaning? Seafoam?
4/12/12 1st bike ever! 95 VN 750 13k
New plug wires
Iridiums
Coil relay mod
MCCT mod
EPA stuff removed
Rear signals shaved
Shinko 170-110 oversized tourmaster tires
Splines lubed
Front signals relocated.
skyboxer is offline
post #4 of 41 (permalink) Old 07-21-2012, 07:28 PM
Well, maybe it is not a fuel issue but an ignition issue.
I would suggest running through all the multimeter tests on your igniter, junction box, ignition coils, and pickup coils.
post #5 of 41 (permalink) Old 07-21-2012, 07:35 PM Thread Starter
Carbs are good and clean, getting plenty of fire. Put 4 new plugs in today.
post #6 of 41 (permalink) Old 07-21-2012, 07:36 PM Thread Starter
The longer it's ridden the worse it gets
post #7 of 41 (permalink) Old 07-21-2012, 07:52 PM
Stones750's Avatar
I am having a similar issue, I noticed it might be clutch related because if I shifted to neutral the rpms were fine when stopping. I agree however to test the charging system. I tried to go on a yearly run today and couldn't get the bike started at the gas station after refilling on the way. The battery was barely turning the starter over and she was hot. I got a jump and rode home, the battery was at 11.6 volts when I tested it and tried to get a reading while running with another jump start. At 4000 rpm the battery is only getting to 12.5 volts and at idle quickly dwindles to 11.6. Battery was load tested days ago and tested good.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #8 of 41 (permalink) Old 07-21-2012, 10:35 PM
Have you adj idle with idle knob on left side under fuel tank?
post #9 of 41 (permalink) Old 07-22-2012, 01:42 AM Thread Starter
Ok just tore everything back apart for what seems like the millionth time. Clogged pilots. So I pulled them and cleaned them,drained the tank of bad gas and put back together. Installed 2 separate fuel filters to catch any further debris. Problem still there. Battery and charging system are fine. Anyone local in Louisville,Ky that's done a shave successfully? I'm frustrated, defeated and about to throw in the towel.
post #10 of 41 (permalink) Old 07-22-2012, 01:46 AM Thread Starter
Btw it's not dying on me now after cleaning the jets. Problem is when taking off up until it reaches the 2500 rpm range and then smoothes out. It's also doing the dead cylinder act until it hits the indicated RPM's. HEEELP
