Carb won't go back on - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-19-2012, 12:16 AM Thread Starter
My buddy and I recently took my carb off to clean it. No problems whatsoever until we tried putting it back on. As soon as we get the front tube on (believe they're called manifolds) and we try to put the back one on the front one pop off. Tries reversing the order, so putting the read tube on then front on but still didn't work. As soon as we readjust it to fit the other tube on the other pops out. Is there some kind of trick or does it just take time and playing with the position?
numb0617 is offline
post #2 of 11 (permalink) Old 07-19-2012, 12:47 AM
I believe the instructions state during disassembly, to leave the left (front carb) boot on the intake manifold....
or do I have that backwards ?
guys....help needed here.
Williamtech
post #3 of 11 (permalink) Old 07-19-2012, 12:51 AM
romeobravo172
romeobravo172's Avatar
There is line up tabs on the boots, plus I think they are marked L&R--
romeobravo172 is offline
post #4 of 11 (permalink) Old 07-19-2012, 12:54 AM
romeobravo172
Also put the throttle cables on before install and think WT is right that one boot stays on the cylinder---
post #5 of 11 (permalink) Old 07-19-2012, 12:56 AM
Yes, be aware, the boots are labeled with L & R, and there tabs to line up during successful installation.
hope this helps
WilliamTech
post #6 of 11 (permalink) Old 07-19-2012, 11:04 AM
deleted
1988 VN750[SIGPIC][/SIGPIC]
FlacoLove is offline
post #7 of 11 (permalink) Old 07-19-2012, 11:30 AM
Crap, I WAS in 5th gear.
One tip is to keep the carbs as HIGH as possible, and then push them down into the boots. Carbs go in from the right and it's best to try and follow Clymer's.
My boots have molded dots on the cylinder side, those dots go outboard.
Carb installation is a rite of passage for a VN750 owner-- it is very difficult the first time.
Kelly2001 is offline
post #8 of 11 (permalink) Old 07-19-2012, 01:05 PM Thread Starter
Thanks for all the advice guys. This was my first time posting and you guys answered so quickly. You're awesome. I'll give it a shot tomorrow and let you know how it goes.
numb0617 is offline
post #9 of 11 (permalink) Old 07-19-2012, 09:42 PM
From the Ear Shave link below.....
When removing carbs:
The front cylinder carb/cylinder rubber boot will REMAIN ATTACHED to the cylinder head during removal of carb assembly
Loosen the carb-side screw ONLY of the front cylinder carb/cylinder rubber boot. This rubber boot will REMAIN on cylinder! (see Figure 10)
Loosen the cylinder-side screw ONLY of the rear cylinder carb/cylinder rubber boot. This rubber boot will REMAIN on carb!
Carefully re-install carb assembly. I found it easier to get the front cylinder connected first, then connected rearů.double check to ensure boots are properly installed/aligned.
VoIPDoc is offline
post #10 of 11 (permalink) Old 07-20-2012, 09:48 PM
Youngster
1stVulcan's Avatar
I ended up taking both boots off to take the carb out. And Just left the two boots off until the carb was in about the right position. Worked but was a little tough to get both boots to go on simultaneously. There's practically no room to move the carbs around in though so it's difficult. I'm gonna try leaving the front cylinder boot on the next time, sounds easier.
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
