Different Inlet Elbow Sizes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-09-2012, 08:18 PM Thread Starter
Youngster
1stVulcan's Avatar
Just bought a brass carb fuel inlet elbow to replace a broken one. It seems this size is supposed to allow greater flow to the carb. I'm keeping the other side carb the stock plastic one since it's not broken. The fuel line I'm using will be 1/4" to each one.
I'm wondering if by having one inlet bigger than the other the amount of fuel in the carb will be affected and thus create some sort of imbalance between the carbs? I'd buy both if I had mo money in tha bank.
1990 VN750 Red and Black
Bought on 6/30/2012 w/ 13,230 miles
At ~20,000
To Do List: Paint Front Rim, Acct- mcct mod
Done: Adjusted Float Bowls, R/R Replace and Relocate, Coastered, Ear Shave, Front/Rear Tire Change, Replaced Final Gear Seals, Splines Lubed, Relay Coil Mod, Replaced Fork Seals, Rebuilt Starter
1stVulcan is offline
post #2 of 5 (permalink) Old 07-09-2012, 08:36 PM
romeobravo172
romeobravo172's Avatar
Do not think so, as carb floats measure that!
romeobravo172 is offline
post #3 of 5 (permalink) Old 07-10-2012, 07:49 PM Thread Starter
Youngster
1stVulcan's Avatar
Alright just adjusted that, hopefully it's set right once the carbs are back on. The elbow inlet comes in like 3 days after I register it, and put it back together I'll be on the road for the first time since buying it!
At ~20,000
post #4 of 5 (permalink) Old 07-10-2012, 07:57 PM
What I have learned on this forum is that fuel elbows are also available at most H-D (st)earerships...
WilliamTech
post #5 of 5 (permalink) Old 07-10-2012, 09:56 PM
Well, yes and no....the most you may need to do (I did when replacing just one) was to open up the idle screw on the carb without a 1/2 turn...no biggie...but I have both increased now to full flow, and it definitely adds to perf...mostly when under load and at top end....I can be in 5th, at 40mph...twist it, and after a low growl, picks right up, no bog, no nuthin....KC can confirm this...I shift early too, to keep them low, gutteral Harley pipe sounds purrin...before I had the high flow, would have bogged...
