throttle bog and coughing - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 07-05-2012, 11:57 PM Thread Starter
Okay, I am a bit of a newb but this site has been my resource. I have been able to find answers to almost any issue I have had with my vulcan here. I bought a 94 a few months ago and it has ran great until recently. It seemed that all of a sudden I had top end sputtering when I gave it a lot of throttle that didn't happen before. After reading as much as I have on here, I decided that it was probably a clogged main jet so I pulled the carbs for a cleaning and rebuild. Thanks to roach's helpful videos, I felt confident enough to do it myself. I thought that while I had them off, I may as well do the earshave and rejetting as well. I followed phil's earshave directions for that. everything went okay (except for a broken bolt at the reed valve which I knew to watch out for, but I still managed to break it off.) I was able to get coastered, shaved, and rejetted, but when I reassembled today, I still have the same top end issue. I plan on syncing the carbs tomorrow, but it still starts and runs well with little throttle. Now the bog down still happens, but there is a coughing and a little smoke at the exhaust manifold when it give too much throttle. I am going to double check all the hoses, boots, etc for an air leak, but I don't think I have one. Could this be an electrical problem? It seemed to start on a really hot day. I'll also check all my connections. Or is this fuel starvation? the petcock? It doesn't die when i give it throttle, but almost. And now I am noticing this coughing with some smoke. but maybe the smoke isn't new but i am just noticing it now because I don't have those giant ears blocking the way. I checked the oil, and it seems fine, but I changed it anyways. Any insight would be greatly appreciated. I am not opposed to taking the carbs back off and re inspecting the floats and whatnot, but i know it cant be the jets since there are new ones in, right? I thought the carb was the issue, and maybe it still is, but I cleaned it thoroughly... again, insight, please! p.s. it is a little rusty around the exhaust, and I think that is where the smoke is coming from, but it only seems to really come when it coughs from me cranking the throttle..
dougdanger is offline
post #2 of 3 (permalink) Old 07-06-2012, 08:39 AM
JM2001's Avatar
I would first check that the fuel enricher plungers are closing. Then I would check the spark plugs for good spark to both cylinders. If those check out ok I would think you have a float or needle valve problem.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 3 (permalink) Old 07-06-2012, 11:34 AM
Might also consider dumping some Seafoam in too. My bike would hesitate at 2K RPM then rapidly climb with a little more throttle. She would sputter and one of the cyclinders would simply quit firing. I added half a can of Seafoam to a full tank; and, HOLY ****, she idles smooth, is real smooth thru all RPM ranges, and has a little more pep than before. I highly recommend this.
Good luck!
Tags
carbs , coughing , exhaust , fuel starvation
