First trip with bike. Puzzling MPG. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-02-2012, 06:34 PM Thread Starter
Hello,
This morning, my dad and I took off for a small road trip, about 200 miles. I made 3 fuel stops: 1 at start of trip; once about 85 miles in; and again about 5 miles from home.
- The MPG at stop 2 was around 51 MPG. Only added 1.66 gallons of gas to top it off. Drove 85 miles before refilling. 2nd fill up since adding Seafoam.
- The MPG at stop 3 was around 37 MPG on reserve. I added over 3 gallons of gas to top it off. Drove 110 miles before hitting reserve. Drove another 5 miles before finding gas station.
- Total trip average of 44 MPG.
The trip out included curvy, hilly roads. The trip back was a straight shot with very few hills and curves. I also had a south wind, not strong enough to slow me down, to deal with on the way back. The bike also has a wind shield installed with it leaning as far back as possible for increase aerodynamics. Nothing about the bike changed from start to finish. It ran like a champ the whole time. Is what I experienced a result of bad gas? Possible the heat caused the gas to evaporate faster? Certainly a slight head wind would not cause a 14 MPG deviation.
I figured the bike was more consistant thanthis. I get better MPG in town than I did during the drive home.
Any ideas? Or am I just being paranoid? Thanks!
post #2 of 20 (permalink) Old 07-02-2012, 06:49 PM
romeobravo172
romeobravo172's Avatar
I average 47 mpg just about all the time. Varried riding,stop and go city, some hwy ect. Fron MY exp be prepared to hit reserve at about 110-120 miles. ( I always set my trip od) This is just my bike and my riding habbits. Some say 55 plus!!
romeobravo172 is offline
post #3 of 20 (permalink) Old 07-02-2012, 06:58 PM Thread Starter
I have never hit reserve during in-town riding. I almost always fill up at or just over 120 miles. For the bike to run out of gas at 110 miles after riding at hi-way speeds seems ridiculous.
post #4 of 20 (permalink) Old 07-02-2012, 07:38 PM
Figuring MPG should be something that is done over a month of riding, NOT by tankful. Your aversge speed, ambient tempature and humidity, how you accelerate and when, slope of the road, wind direction, etc... all play a part here.
I've gotten less than 38 mpg to over 50 mpg... All dependant on how hard I'm riding to average speed , to yes , even the gas I used. (and the above)
Frankly.... I don't care. I get gas when I need it and don't give a crap what mpgs I'm getting unless they were to fall well below my lowest reading over more than one tankful or two.
post #5 of 20 (permalink) Old 07-02-2012, 08:00 PM
I mentioned this in another thread....but it fits, so here I go again...lol
"For the bike to run out of gas at 110 miles after riding at hi-way speeds seems ridiculous. "
not ridiculous...it all depends on your idea of a "full tank"
I never hit reserve, but usually fill up around 100 miles. If you fill the tank to the very top (gas up to, or part way up the tube "neck" under the filler cap). you will most likely be somewhere around 140 miles to reserve ( just an average).
If you are not comfortable with filling it that high and end your filling somewhere below that filler neck, you are losing about 30 miles worth of fuel (again...just an average).
If you are averaging 50MPG, then you are doing OK....If you are running wide open on highways, then expect less. It also has to do with a lot of factors like weight, wind resistance (windshields for example) and how you throttle and brake.
I wouldn't worry too much unless you are falling below 30mpg...then check your oil for gas in it or some sort of carb/ignition issue.
Bottom line...if it runs good and gets you there...enjoy the ride my friend!!
post #6 of 20 (permalink) Old 07-02-2012, 08:43 PM
X2 kc2 !
post #7 of 20 (permalink) Old 07-02-2012, 10:34 PM
IMBoring25's Avatar
The worst tank I ever had on the VN750 was 40.9 at 75 MPH on the turnpike into a headwind. The suburban commute I had when I first got it was frequently worth mid-to-high 50's. The subsequent predominantly-highway (60-65) commute kept me working to hit 50. The bike has low gearing and not the best aero in the world, which means high speeds hurt the MPG a lot. Was the straighter run not a faster run?
IMBoring25 is offline
post #8 of 20 (permalink) Old 07-02-2012, 10:37 PM
Well ridin the stick country I can't always get gas, so I try to hit the sticks full up...
One thing on my bike that was shortening my fill ups was the kickstand (seems like kickstands always give me trouble...lol...) it was a good bit short in my opinion (not a VN750) and the bike had so much lean that you did not get a tank full, I had 3.5"s added in the middle of my Sportster kickstand and now get 25-30 more miles on a fuller tank, that gives me a happier feeling in the mountains where fill ups are a good bit apart... (And no I'm not goin to set a straddle of my hot bike and hold it streight up to fill'er to the brim, they may be useless but I don't want'em cooked yet...lol...)
On the VN750 as I remember I usually got 120+ before reserve, wish my Sportster had the reserve instead of the faulty idiot low fuel light...
post #9 of 20 (permalink) Old 07-02-2012, 11:08 PM
HAWK
Ccspinner's Avatar
Get the bike at 80 or faster and it will suck the tank dry fast.
I was loaded for a trip and doing 80+ got in the 30's. Slow down to 60 and was getting mid 40's.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 20 (permalink) Old 07-03-2012, 01:40 AM
Ndr
My daily commute is about 95% highway and I'm typically pushing 80mph or more each way as most of the ride I see very little traffic until I get close to the city. I'm usually hitting reserve at between 100-110 miles.
Ndr is offline
