carbs with minds of their own - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-30-2012, 01:32 PM Thread Starter
my 750 runs but when you set idle at 1100, it will stay there about 30 seconds then climb to round 4000. then you have to readjust but it will do it again. bike is stock .
vulcan98 is offline
post #2 of 3 (permalink) Old 06-30-2012, 02:13 PM
Obviously this happens with the engine warm/choke off. Definitely an _Air/Fuel_ issue if it always stays smooth...(as in not running on one cylinder spadically). I might suggest checking the air intake system...maybe a carb boot not sealed....or even a possible vacuum leak ?
Others on the forum are able to assist you better than I.
hope this helps
WilliamTech
post #3 of 3 (permalink) Old 06-30-2012, 02:18 PM
........Stole this from Swagman:
Also, Try your air mix screw sounds like it could be a little on the lean side, try 2 1/2 turns out to begin with and work from there, hope this helps.
