stripped spark plug help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-29-2012, 01:08 PM Thread Starter
Hey...just got a 1993 vulcan the other day. changed 3 spark plugs without issue but couldn't replace the fourth one. The threads are stripped. I've look into the heli coil...fix-a-thread thingy majiggies but can't find the right size. I think I need a 12mm with a 1.25 thread pitch...Does anyone know anything about this?? Where to find it, how to do it or other ways to go about fixing this?
thanks,
Carollynne
warmheartedrebel is offline
post #2 of 7 (permalink) Old 06-29-2012, 01:17 PM
thanks,
Carollynne
I think the whole spark plug hole can be changed.
See part 92066 on this image.
92066 PLUG,CYLINDER HEAD
Might just be for the deeper ones? I am sure others will have more details.
post #3 of 7 (permalink) Old 06-29-2012, 01:33 PM
Only 2 of 4 spark plugs have #92066 Plugs...if your stripped threads are one of the two you are in luck. The #92066 Plug requires a special tool to remove & replace. Mech's remove #92066 plug by removing the rear axle Nut, inserting it into the plug and wrench on the axle Nut.
Hope this helps
Williamtech
post #4 of 7 (permalink) Old 06-29-2012, 04:32 PM
If it is one of the other two, Helicoil makes one specifically for spark plugs and aluminum heads. http://www.amazon.com/Helicoil-5334-...0998319&sr=1-1
post #5 of 7 (permalink) Old 07-03-2012, 03:52 AM
Let's Ride!!
DaveT319's Avatar
92066 is just a sleeve. The hole that the spark plug actually screws into that goes into the cylinder is drilled into the cylinder. So no matter which plug it is, he's going to need the helicoil.
DaveT319 is offline
post #6 of 7 (permalink) Old 07-03-2012, 04:01 AM
I stand corrected
post #7 of 7 (permalink) Old 07-04-2012, 01:51 AM
Ndr
^^ Was gonna say this but he beat me to it.
Ndr is offline
