running lean - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-27-2012, 09:42 PM Thread Starter
gun slinger
centurynick's Avatar
running lean
well judging by my exhaust ( the inside is white) im going to say my rear cylinder is running lean .. so off come the carbs it idles and runs pretty darn good no real problems ( well it doesnt seem to have the a$$ in the big end like it did .... like up past 90mph 6K+ rpms ) it also seems to run hotter like cruising on the hwy in 80+ degree shes runs almost half way on the gauge the needle almost touching the left side of the thermoter symbol when on the hwy for more then 20 mins . so what am i looking for the carbs were cleaned 2 years ago. i run sea foam regularly there a jet that may be partially plugged when im WTFO or cruising on the hwy ? i dont want to turn my new pipes gold lol and i dont want to start melting stuff down yet so i guess im looking for ideas on what to look for
2010' voyager
2005 1600 nomad sold
1987 kawasaki vulcan 750 SOLD
1985 kawasaki vulcan 700 parts bike maybe
lots of hand guns
3 cagers doors kicked in
centurynick is offline
post #2 of 5 (permalink) Old 06-27-2012, 11:17 PM
Crap, I WAS in 5th gear.
Your plugs are the best (easy) indicator of mixture. Compare the front and rear ones and report back. You may just need a shim or two under your main needle.
Kelly2001 is offline
post #3 of 5 (permalink) Old 06-28-2012, 01:58 PM Thread Starter
gun slinger
the front pipe is bluing up near the cylinder head it has soot ( black inside ) the rear pipe inside is white . the only reason i pulled the pipes is i bought cruizers i have never seen the inside of a exhaust pipe white ....
2010' voyager
lots of hand guns
post #4 of 5 (permalink) Old 06-28-2012, 02:54 PM
JM2001's Avatar
Bluing near the head is a lean condition. Rear pipe white inside also lean. The rear pipe white is a symptom of the carb getting too much AIR. Restrict your air filters a little and see if it makes a difference.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 5 (permalink) Old 06-28-2012, 08:47 PM Thread Starter
gun slinger
i found the left ears air filter was dry and a big chunk was missing this is probably a big chunk of my lean condition
2010' voyager
lots of hand guns
