Carb Removal or else - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 08-16-2006, 11:21 PM Thread Starter
Ive been having trouble lately.While idling,the rpms will jump from about 1100rpm to about 1250rpms for about 3 seconds,then go back to 1100rpms.It sounds like one of the cylinders is not firing or getting gas.When I lean the bike to the right,while idling,the rpms go up.I can ride for about 13 miles ok,then all of a sudden,while in low gears,it starts wanting to die.I have to rev it up,to get home quick.It sounds like,blub,blub,blub,blub.I drained the carbs.The left side drained about a cup of gas.The right side drained about a 1/4 of a cup of gas.I could hear gas boiling or something on the left side.The gas tank vent was hissing.When I opened the gas cap,it made a noise like psssssssss.Alot of pressure in the tank.Also,I have noticed that the left carb will leak around the shaft that moves the butterfly valve or around the choke plunger.My quess, is that the valve seat on the float is not working.Stuck or whatever,letting gas just flow over.I just want to make sure that this problem is my carbs,#1 and not something else.Any help will be greatly appreciated. Steve
ssmendez is offline
post #2 of 18 (permalink) Old 08-16-2006, 11:30 PM
Sounds like you have 2 problems, some carb issue and that your tank vent is blocked. Easy way to check the tank vent is to disconnect the vent hoses (under the seat, 2 small hoses at the base of the tank). Start up the bike, when it starts to sputter and wants to die, disconnect the hoses, if it starts running good again, then you have a blockage in the vent/evap system.
Safety tip: Don't leave these hoses disconnected as raw gas and gas fumes vents out of the tank into them (right above the rear cylinder exhaust manifold).
Imnohero is offline
post #3 of 18 (permalink) Old 08-16-2006, 11:41 PM
HAWK
Ccspinner's Avatar
Some tanks only have 1 hose on the tank. California bikes have 2.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 18 (permalink) Old 08-16-2006, 11:57 PM
Once Banned
cegodsey's Avatar
Make sure after you getting everything back together that you check/change your oil. Just in case any of the flooding on that cylinder got past the rings and into the crankcase. But it sounds to me like you're on the right track.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 18 (permalink) Old 08-17-2006, 12:20 AM
95VN750's Avatar
That is almost the same thing that happened to me... right after filling the tank.. blub, blub.. ran bad all the way home. after a trip to the dealer, it turned out to be a plugged vent hose.
All was good after that!! Check the little things first.
If you have an air compressor you can blow through the vent tubes to see if they are plugged.
1980 440LTD
1976 KZ900
1995 VN750 19,500 miles ( start of '08 season ) All mine!
Can't have too many Kaws!
95VN750 is offline
post #6 of 18 (permalink) Old 08-17-2006, 12:29 AM Thread Starter
Me again
Im not sure where the vent hose is.I thought that the tank vented from the cap?
ssmendez is offline
post #7 of 18 (permalink) Old 08-17-2006, 03:16 AM
Once Banned
cegodsey's Avatar
Unless I'm mistaken, it's the hose under the seat at the back of the tank. It's for emissions laws. Goes into an evaporative cannister.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #8 of 18 (permalink) Old 08-17-2006, 12:00 PM
HAWK
Ccspinner's Avatar
Only goes to a canister on Clifornia bikes. Mine just hangs down in front of the swing arm. If I fill the tank and park in the sun it will drip out gas due to the heat. only 3 or 4 drops but I can see a spot on the ground
Chad Falstad "Hawk"
Vroc #17649
post #9 of 18 (permalink) Old 08-17-2006, 07:14 PM
Once Banned
cegodsey's Avatar
Good! that explains the smell of gas I had after I parked it in the garage yesterday.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #10 of 18 (permalink) Old 08-17-2006, 08:00 PM Thread Starter
carb questions
Does this hose connect to the petcock? or are the two lines from petcock just vacume lines to suck gas when engine is running? Does anyone have a picture of this fuel vent line? When I say,that I drained about a cup of gas out of the left carb,does that sound like a stuck float needle?how much gas is usually in the carb? SteveAlso,my bike is an '86 with 21,000 miles.
ssmendez is offline
