DAMNIT - Leak! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-18-2012, 09:54 AM Thread Starter
Angry DAMNIT - Leak!
Went out for a nice ride yesterday, a Father's Day treat while the kids were napping...
Come home and the bike smells of gas. F*#@. Checked it out today, and lo and behold - the tank has failed where the rear mount is welded on. Somewhere underneath that bracket there's a crack or one of the welds pulled out or something and it's leaking enough to put a small puddle on the floor overnight.
Can I get this welded up? Or does anyone have a tank? The one the PO put on my bike is from a 00-01; if someone has a different one I guess I could sell my side covers and get new ones to match...
Please Help!
'86 VN750
Pickup coil mod
Iridium plugs
New CDI Ignitor
Clutch Basket Mod
Nebraska68 is offline
post #2 of 4 (permalink) Old 06-18-2012, 10:07 AM
You should be able to repair that. Either welding or brazing would do well. Both options will require a touch up paint. I'm not sure if you could seal it with some sort of fuel resistant epoxy or something.
post #3 of 4 (permalink) Old 06-18-2012, 11:17 AM
You could weld it. However, this is EXTREMELY DANGEROUS with a fuel tank (i guess gasoline vapors like to ignite or something...). Be sure to take appropriate precautions.
I have used JB Weld to seal leaky fuel tanks before. You need to make sure it's well prepped and has no grease/gas there when you apply it. Once cured, grind/sand it down and touch-up paint if you feel it's necessary.
Hippie
2005 VN750 upwards of 14K (haven't looked lately)
Mods:
AGM Battery
Degoated
Headers wrapped
Custom paint
hot_rod_hippie is offline
post #4 of 4 (permalink) Old 06-18-2012, 11:32 AM
JM2001's Avatar
I have used this JB Weld on tanks.
http://jbweld.net/products/industro.php
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
