jet sizes for straight pipes - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-17-2012, 06:38 PM Thread Starter
Hey all,
Just put set of custom straight pipes on my 99 vn750. I don't want to go through the trouble of taking the carbs on and off just to find the right size. Any suggestions? Altitude is whatever Illinois is and its binge stick other than pipes. Thanks
99vn_750 is offline
post #2 of 5 (permalink) Old 06-17-2012, 08:03 PM
My suggestion is to put the stock pipes back on. You'll never make the bike run better with straight pipes....all you are doing is making more noise.
If you do an earshave.... You will have to re-jet and will
Have to remove the carbs to do so.
post #3 of 5 (permalink) Old 06-21-2012, 01:13 PM
pittdave's Avatar
mine is in the shop with V/H Cruzers and the will be putting on 137-139 on the main as a recommendation from V/H
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #4 of 5 (permalink) Old 06-22-2012, 06:22 AM
2FAS4U
Our 86 came with straight pipes and no mufflers. I took them off because we never could get the bike to run right. Nor could the previous owner.
Have Vance and Hines on 2 bikes with no jet changes.
2fas4u is offline
post #5 of 5 (permalink) Old 06-22-2012, 04:28 PM
Stones750's Avatar
x2
Mine came with the exhaust butchered and it has been a pain to get the pipes the same length not to mention all the quirks etc. this causes and the backfiring...but as long as you haven't increased air intake (ear shave or K&N filter) you need to go up one step on pilots and mains may even need to shim the needles with one shim each. it is possible to do the pilots and mains with the carbs still on but it isn't easy at all and you will need to remove the front cylinders acct in order to get full motion on an offset screwdriver.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
