Carbs Flooding Engine, - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 06-17-2012, 01:53 PM Thread Starter
Hi,
Just putting my vulcan 750 together & getting it running, it seems now that the carbs are constantly flooding resulting in fuel spilling down the engine, also it looks like the carbs are flooding the cylinders because there was an almighty bang from the head, I thought a piston had hit something!
but it started fine after, its also running quite rich.
the bike has been mothballed during last winter while I did some work on it, prior to that I had changed the float needles in the carbs.
I appreciate your help!
Chris
Mcr Uk
Chris.Mcr is offline
post #2 of 8 (permalink) Old 06-17-2012, 02:04 PM
Sounds like stuck floats or maladjusted float level.
post #3 of 8 (permalink) Old 06-17-2012, 02:32 PM
sounds like stuck floats or maladjusted float level.
x2 !
post #4 of 8 (permalink) Old 06-17-2012, 02:34 PM
romeobravo172
romeobravo172's Avatar
Keep an eye on your oil and level! You say flooding the cylinders, would almost bet you are getting fuel in the oil!
romeobravo172 is offline
post #5 of 8 (permalink) Old 06-17-2012, 04:33 PM Thread Starter
vulcan 750 flooding carbs
Thanks for that chaps!
when I tried to start the bike this afternoon it made a big bang and I pushed the start button again and it was as if the engine was stuck ie would'ent turn over!
It did start and run after that though,
do you think there is any serious damage, like that bang being a piston or somthing?
Ride Safe
Chris.
Mcr UK
post #6 of 8 (permalink) Old 06-17-2012, 05:11 PM
Ride Safe
Chris.
Mcr UK
As long as it is running and performing fine, it should be OK. People have had backfire come out of the air boxes (and blow them off...) before.
post #7 of 8 (permalink) Old 06-18-2012, 09:19 AM
Ride Safe
Chris.
Mcr UK
I would get the flooding sorted out and not keep starting it, sounds like you are getting too much fuel into your piston chamber and stopping the engine turning over, if you keep trying to start it like that you may do some serious damage to the con rods .
Swagman is offline
post #8 of 8 (permalink) Old 04-03-2017, 03:45 PM
So I am having the same issue here, I started my bike and the RPMs sky rocketed to the top and I heard a loud bang that had all the neighbors scared. I was having issues before when I was starting the bike and looks like out of habit I turned the throttle to many times when trying to start and I think the fuel might be leaking from the carb to other systems. How can I check if that is true? and how would I remedy the situation?
spbruski is offline
Tags
carbs , flooding , fuel , gas
