top end question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 06-15-2012, 12:48 PM Thread Starter
Stones750's Avatar
top end question
I was getting a bit wiley the other day and noticed my bike does not want to go past 7k rpm. It's almost like a rev limiter-this happens in any gear. Basically with wide open throttle it doesn't miss or hesistate untill 7,000 rpm then it starts to rap out, I'm pretty positive these bikes do not have a rev limiter and I'm at 140 on the main jets with drag pipes and ears shaved @ 5,280 ft. elevation. This problem was the same with 138 mains as well. Now it pulls better with the 140's but still cant get past 7k. Any ideas guys?
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
Currently @ 23k and counting
Stones750 is offline
post #2 of 7 (permalink) Old 06-15-2012, 12:53 PM
Where is your breather pipe do you have it cut to 45degree angle and stuck in the right ear, if it is caught by the wind rush it can cause a vacuum and bog the bike down.
Swagman is offline
post #3 of 7 (permalink) Old 06-15-2012, 01:00 PM Thread Starter
Stones750's Avatar
The carb breather hose is inside the frame tubing-theres a hole just under the tank that keeps the hose outta the wind -Ears shaved-
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #4 of 7 (permalink) Old 06-15-2012, 02:12 PM
What kind of air filter are you running?
post #5 of 7 (permalink) Old 06-15-2012, 02:52 PM
JM2001's Avatar
Sure, at that elevation your jets should be at least 2 sizes DOWN. Too much fuel and thinner air.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #6 of 7 (permalink) Old 06-15-2012, 05:34 PM Thread Starter
Stones750's Avatar
True, the elevation here does require two steps down with a stock setup. However most near sea level or between are running 140's with stock exhaust and the ear shave. I have straight pipes which lean the mixture. The problem was the same with 138 mains as well. It pulls stronger near the higher rpms with the 140's but even with 135's (which are confirmed to lean by a dyno) the problem still exists. It's not like a rich condition where you let off the gas and the bike resumes cruising. It is like hitting a rev limiter, it gets to 7k and bounces a little while making the same sound a bike with a rev limiter would. It will not rev past 7k even if I'm not at WOT (3/4 or less in a lower gear). The bike will accept WOT in second gear from 2300 rpm up to 7k. Maybe I'll just keep the old girl under 7k lol.
86 Vn750
De-Goated
Ears shaved
"Custom Pipes"
"Custom Seat"
Apes
Stator Mod
post #7 of 7 (permalink) Old 06-16-2012, 01:08 AM
Try your vaccuum hose to the intake and petcock. also the best air filters to use are the k&n pods.
