vn750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 06-14-2012, 11:18 PM Thread Starter
vn750
my 750 runs pretty good but after i ride it for a bit then shut it off i have to use choke to get it to start back up. new battery, irridium plugs new voltage reg,put a battery tender on it new pick up coils, different stator. any suggestions would be great
vulcan98 is offline
post #2 of 15 (permalink) Old 06-15-2012, 02:48 AM
So this only happens when it's warmed up or do you have to choke it to start it cold too.
post #3 of 15 (permalink) Old 06-15-2012, 07:00 PM Thread Starter
sometimes have to use choke when cold but most time no
vulcan98 is offline
post #4 of 15 (permalink) Old 06-15-2012, 07:05 PM
What setup you got, stock bike coastered earshaved stock pipes aftermarket rejetted, so many variables we need a little more info
Swagman is offline
post #5 of 15 (permalink) Old 06-16-2012, 10:54 PM Thread Starter
stock pipe,pipes and all.
vulcan98 is offline
post #6 of 15 (permalink) Old 06-16-2012, 10:55 PM Thread Starter
oops meant stock bike, pipes and all
vulcan98 is offline
post #7 of 15 (permalink) Old 06-16-2012, 11:08 PM
Sounds like a good time to say "SeaFoam".... Could just be dirty jets.
And that's an AGM "new battery" right?
And I also think you win the award for the least informative thread title....
post #8 of 15 (permalink) Old 06-16-2012, 11:15 PM Thread Starter
sorry not much to say about it, its a 1996 vn750 all stock battery from wal-mart put in different stator 2 months ago, repainted was blue/grey now emerald green mettalic with prism effect ( paint is from dupont)
vulcan98 is offline
post #9 of 15 (permalink) Old 06-18-2012, 09:59 AM
Try your air mix screw sounds like it could be a little on the lean side, try 2 1/2 turns out to begin with and work from there, hope this helps.
Swagman is offline
post #10 of 15 (permalink) Old 06-30-2012, 01:44 PM Thread Starter
ok adjusted carb now runs at 1100 for about a minute then revs to 4000, any ideas as to why?
vulcan98 is offline
