alignment of rubber carb mounts.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-12-2012, 01:22 PM Thread Starter
photobuff4u's Avatar
Hi all...need some advice.....The manual said position the marks to mount the carbs, what are the position marks, are they on the carbs or on the engine.....and what do they look like...All I saw on the mounts was the notation "front" and "rear" are those considered the positional points they mean....Should have paid more attention when I pulled them out......hindsight great teacher uggggg.....
photobuff4u is offline
post #2 of 6 (permalink) Old 06-12-2012, 01:30 PM
Crap, I WAS in 5th gear.
There are molded dots on the ends of the cylinder side. The dots go outboard (3 O'clock and 9 O'clock.)
Kelly2001 is offline
post #3 of 6 (permalink) Old 06-12-2012, 01:34 PM Thread Starter
Thanks so much..going back out to try again...this time with good info.....
post #4 of 6 (permalink) Old 06-12-2012, 03:20 PM Thread Starter
Thanks again for your input, aligned the marks as you described and presto everything went into place.....thyis site is a wealth of info......just got this 750 a short time ago, and learning every day something new and exciting......
post #5 of 6 (permalink) Old 06-12-2012, 03:27 PM
Glad to help. It took me a while to figure that one out. I don't know if is described very well in any manuals. So you got your carb seated in under two hours? Some of us have spent days! As usual with this bike (and most any wrenching,) the next time you do it, it will only take you 1/4 of the time as the first.
post #6 of 6 (permalink) Old 06-13-2012, 08:25 AM Thread Starter
It was very frustrating process, as I had the carbs out a total of three times...had them in, but when installing air duct pieces, they were at the wrong angle and clamping was impossible....carbs have to line up right, so other componants also fall into place......you are so right about time factor....next time it won't be a day or two long event....thanks so much again.....
