Tank Removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 06-03-2012, 03:26 AM Thread Starter
Skankin' Vulcan
combatchuck's Avatar
Tank Removal
Hi guys, i've seen a few threads on gas tank removal, but no step by step walkthrough stuff. From what I've seen it isn't too hard but this is my first bike and I've only had it for a month or so. Can you give me a rundown on tank removal or point me to a thread on it? I'm getting it painted.
Combatchuck
Looking for:
Swingarm caps
Highway pegs or engine guard
PM if you got these for sale
1986 Vulcan 750
NGK Plug Wires and Iridium Plugs
AGM Battery
Shinko 230 Tour Masters @24,400 miles
Right side rebuilt after PO laydown
combatchuck is offline
post #2 of 19 (permalink) Old 06-03-2012, 03:48 AM
2 bolts up front, one in rear, disconnect fuel level sensor, dissconnect vent tube and dissconnect vacum and the two fuel lines on petcock and it's off.
Rebel13 is offline
post #3 of 19 (permalink) Old 06-03-2012, 03:51 AM
Patriot Guard Rider
The DEUCE's Avatar
1. Close petcock
2. Remove vacuum hose from petcock
3. Remove two fuel hose from petcock
4. Remove the seat
5. Unplug the Fuel Float (White 2 prong plug)
6. Remove one bolt from the base of the tank
7. Remove any hoses that may be attached at the base of the tank
8. Remove two bolts (one on each side of the tank)
9. Remove tank
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 19 (permalink) Old 06-03-2012, 04:29 AM Thread Starter
Skankin' Vulcan
Should I drain the tank first? How do I do that ?
Combatchuck
Looking for:
Swingarm caps
1986 Vulcan 750
AGM Battery
post #5 of 19 (permalink) Old 06-03-2012, 04:34 AM
No need to drain the tank for removal, btw it is heavier with more fuel in it. No need to move the petcock in any direction, it won't leak either way.
Rebel13 is offline
post #6 of 19 (permalink) Old 06-03-2012, 08:52 AM
without vacuum on the petcock, there fuel should not flow.....if you have a petcock with the "Prime" position on it, I would recommend you not leave it in that position....just sayin
post #7 of 19 (permalink) Old 06-03-2012, 12:47 PM
X2 And if your bike is a standard 86 it will have prime.
Swagman is offline
post #8 of 19 (permalink) Old 06-03-2012, 01:11 PM
That is true. I didn't realize how old his bike was.
Rebel13 is offline
post #9 of 19 (permalink) Old 06-03-2012, 01:49 PM
I kept the gas in my tank when I removed it last time. No leaks from my 86's petcock, so I think you'll be OK too.
post #10 of 19 (permalink) Old 06-03-2012, 05:12 PM
Ndr
Yup, any setting other then Prime *SHOULD* not allow gas to leak when the hoses are off the petcock. Off is of course the safest and so easy to do there's no reason not to take that extra insurance against spilling fuel.
Ndr is offline
