Carb removal and cleaning. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-02-2012, 08:50 PM Thread Starter
Just a regular guy
Chris32250's Avatar
Ok, after reviewing my Clymers manual and watch Roach's videos I think I am going to attempt to clean my carbs. My issue is not so much ability as it is time and space. But I am off tomorrow. Is this something that should be able to be done in 4-5 hours with no garage? Any special tools I need? Anything I should look for while in there or anything I should do extra. I am not going to spend a bunch of money till I get it running reliably for an extended period of time, since it hasn't since I bought it last year. But if something is a basic item while I have them apart I might...
Any extra pointers and tips would be super appreciated.
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #2 of 4 (permalink) Old 06-03-2012, 07:13 AM
No special tools just a good serving of patience, they are a major PITA to get on and off but to work on when you have them out is quite a doddle, I would do a search on here for others that have done this as there are quite a few topics that will run you through the procedures, and good luck with the patience bit of the job.
Try here https://www.vn750.com/forum/showthread.php?t=20654
Swagman is offline
post #3 of 4 (permalink) Old 06-03-2012, 07:30 PM
Papa Smurf's Avatar
I actually just did this and just finished a few hours ago! Personally, I would give yourself more time. Never having done it before it took me a good 3 hours just to disconnect things and make sure I was doing everything ok w/o the risk of damaging an air duct. On the way back in it only took 30 minutes or so. That surge tank is a pain in the A$s. I ended up not moving the wireharness or the upper coolant stuff. Just watch that metal tube into the left top side of the rear cylinder- if you pull up on the surge tank too much it may send a little bit of coolant out if it isn't tight (the bolt holding it against the head).
But still- take your time. I had to leave my carbs sitting out over night with liquid wrench on them because the 3 screws holding the floats were about to strip.
Here is another video to watch:
http://www.youtube.com/watch?v=nKIzp...ure=plpp_video
He took apart our carbs as well.
Papa Smurf is offline
post #4 of 4 (permalink) Old 06-04-2012, 02:52 PM
Papa Smurf's Avatar
One more thing- what helped me immensely getting the carbs back in was pausing to see what I was running into. The hang up at my end was the front carb bowl would end up in the front boot that remains attached to the engine. After I saw that it just involved some playful up and twisting to seat it. Man it feels good when they fall into place.
