help! stranded! no gas in the lines! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 17 (permalink) Old 05-18-2012, 07:32 PM Thread Starter
Acolytes of Perdition
beeblebrox82's Avatar
Arg! Went out for a ride, bike stalled and would not restart. Battery was not very strong restarting, and then died.
Got a jump, even turning over strong it won't fire. The fuel lines are empty, or only partially filled... not filling, even on prime. Moving the petcock back and forth doesn't help. Also seems like I,ve got a lousy seal at the cap. Leaks fuel a bit. Any ideas? Tank is full.
Thanks!
beeblebrox82 is offline
post #2 of 17 (permalink) Old 05-18-2012, 07:33 PM Thread Starter
Was riding fine before for about an hour
post #3 of 17 (permalink) Old 05-18-2012, 07:39 PM
Try starting and running with the fuel cap open.
Rebel13 is offline
post #4 of 17 (permalink) Old 05-18-2012, 07:45 PM Thread Starter
Hah. That got it.
post #5 of 17 (permalink) Old 05-18-2012, 07:54 PM
Good deal. Clean the vent lines for the cap/tank aka: poogs.
Rebel13 is offline
post #6 of 17 (permalink) Old 05-18-2012, 07:59 PM Thread Starter
Thanks. I've heard of this issue before now that you mentioned it. Sorry, working from my blackberry, should have done a better search, probably a million threads. Still worried about charging, was pretty soft cranking.
post #7 of 17 (permalink) Old 05-18-2012, 08:01 PM
No problem, it is a vacum lock, bad design.
Rebel13 is offline
post #8 of 17 (permalink) Old 05-18-2012, 08:59 PM Thread Starter
Question, have people experienced poogs with more than half a tank? My gas tank was nearly full.
post #9 of 17 (permalink) Old 05-18-2012, 09:09 PM
It's the same at any level. With less fuel in the tank it is actually less noticable, air is compressable and liquid isn't. When you get a positive pressure, that is when your cap is leaking that you have mentioned. When it is negative it starves the carbs.
Rebel13 is offline
post #10 of 17 (permalink) Old 05-18-2012, 09:15 PM Thread Starter
roger that, will clean out the venting stuff. Thanks much!!
