Petcock tube fell out again
Pushing the tube back into my petcock doesn't seem to be doing the trick. While out on a short ride tonight I noticed one cylinder kick out, looked down and saw fuel just streaming out. In fact the gas gauge even dropped down. Scarry. I'm thinking about using vice grips to slightly deform the tube and then shove it back in or just replace it (even though I just put a $40 rebuild kit on it). Has anyone else had this experience? Did you try deforming it? It doesn't leak at all when I shove it back in.
-Robert
-Robert
Sponsored Links | |||
don't bend it... just mar it up a little bit... use 80 grit sand paper, the use jb weld to secure it in place.
and use a brass hammer to carefully tap it all the way home. some of the designs are tapered, not sure on the vn. if you deform it it will leak forever, i think. i would give it some pretty decent love taps before trying any glue, myself. i have had luck fixing them in that manner.
2003 VN1500 Nomad FI Bagger
2004 KLX400SR Dual Sport light adv bike
1969 CB750 K0 sand cast #1767
couple of nice GL650 Silver Wing Interstates, one with hack
2 and 4 stroke dirt bikes
other vintage stuff back in the corner
I just had this problem (see the carbs and fuel forum). I tried deforming it and it stayed together but just leaked all the time. I used Permatex Liquid Metal filler on the joint and it worked great. Solid.
'86 VN750
Pickup coil mod
Iridium plugs
New CDI Ignitor
Clutch Basket Mod
Originally Posted by Nebraska68
View Post
-Robert
I put a dab of JB weld on mine, then "vised" it together from both sides using channel locks. Those fittings are pressed in, once you deform, will leak. Try the JB and channel locks. Mine have been fine for 600mi since.
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
