Need photo of spring attachment on carbs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 05-16-2012, 09:14 PM Thread Starter
Tech/Musician/Friendly
AudibleCreations's Avatar
Post Need photo of spring attachment on carbs
I am looking for photos of the starter rod (#46102) as well as the spring assembly's for the rod. The parts diagrams found online are too simple to tell how the springs actually attach to the carb body and in which direction the rod sits on each carb. Any help would be much appreciated!
AudibleCreations is offline
post #2 of 7 (permalink) Old 05-16-2012, 10:09 PM
2000 VN 750 Senior Member
I would suggest you watch the video by Roach on Carb Rebuilding. That should be your best bet as you will have a good visual and audio on the different parts of the carbs. Roach has several videos linked here and all have been highly recommended for their excellent information. You can do a search to find the link. I am sure others will soon join in with their helpful information also.
Good luck.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #3 of 7 (permalink) Old 05-17-2012, 10:01 AM
Swagman is offline
post #4 of 7 (permalink) Old 05-17-2012, 12:53 PM
Roach's Avatar
Unfortunately I don't think this was well documented in those videos.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #5 of 7 (permalink) Old 05-17-2012, 10:09 PM Thread Starter
I was able to get a decent look at a picture showing the spring assembly on VoipDoc's ear shave page and then through trial and error figured out the rest. Thanks for being there guys!
post #6 of 7 (permalink) Old 05-18-2012, 11:22 AM
Your welcome, it was trial and error with me when I had mine off but I couldn't explain how i did it
Swagman is offline
post #7 of 7 (permalink) Old 05-18-2012, 12:53 PM
I just want to reiterate the value of making a digital camera a must have tool for any first time disassembly project. Things go back together so much easier when you have a reference point to look back on.
Tom
Vulcan 2000
4507 miles
