K&N Filters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 05-15-2012, 02:11 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
K&N Filters
I put the K&N filters on when I got my bike back together. I'm noticing now that I'm getting about 25 miles less out of each tank of gas. Was I supposed to make any sort of carb modifications using these?
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 19 (permalink) Old 05-15-2012, 02:45 PM
Roach's Avatar
Yeah, you'll need to change the jetting, shim the needles, and adjust the tuning.
Search for "Ear Shave" on here to find lots of info on the process.
This is the kit I used. Warning, Factory Pro's website is terrible.
Here's a link to the verses Ear Shave Page
Edit: I just searched for the product number and found these two sites that sell it. They look to be cheaper and more user friendly than that Factory Pro one.
Amazon
StarCycle
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #3 of 19 (permalink) Old 05-15-2012, 02:55 PM Thread Starter
peterherrm's Avatar
Amazon
StarCycle
Is what I did considered an ear shave? I still have the ears, I just put K&M filters in place of the stock foam ones.....
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #4 of 19 (permalink) Old 05-15-2012, 03:05 PM
No you are still running stock
Swagman is offline
post #5 of 19 (permalink) Old 05-15-2012, 03:16 PM Thread Starter
peterherrm's Avatar
So I don't need to make any other modifications? Don't get why my milage is worse now...
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #6 of 19 (permalink) Old 05-15-2012, 03:17 PM
That is not considered an ear-shave. They technically shouldn't affect your MPG that much, but they could be allowing more air through which is affecting it.
post #7 of 19 (permalink) Old 05-15-2012, 04:15 PM
Roach's Avatar
Whoops, I miss understood.
That's weird then. I suppose more airflow would require some adjustment. Maybe do a carb sync.
Street
Dirt
Roach is offline
post #8 of 19 (permalink) Old 05-15-2012, 04:36 PM Thread Starter
peterherrm's Avatar
Sorry, guess I was a little vague, there's a lot of different kind of K&N filters...
I'll put the stock ones back in and see if there's any change...
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #9 of 19 (permalink) Old 05-15-2012, 04:45 PM
Member? ... check.
ZCraggRatt's Avatar
The K&N filters need to be oiled too right ?
~~C8>
ZCraggRatt is offline
post #10 of 19 (permalink) Old 05-15-2012, 04:47 PM
How far out have you got the idle screws, is she running to rich, check the plugs and see if they are burning clean, if it is rich then you will use more fuel.
Swagman is offline
Tags
air filter
