86 vulcan750 hard start... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-14-2012, 05:42 PM Thread Starter
photobuff4u's Avatar
Hi all...have an '86 vulcan750 w/10k miles on it. Can't get it to start except with starting fluid. Battery new mf/fully charged. Adjusted acc and dec cables , and choke as well. really baffled...when It starts will not stay running unless I give it some throttle. Good spark from plugs, gapped correctlly...Trying to get this beast running so I can ride this season......any thoughts...thanks
photobuff4u is offline
post #2 of 16 (permalink) Old 05-14-2012, 06:03 PM
Patriot Guard Rider
The DEUCE's Avatar
Welcome to the VN750 Insanity.
It sounds like a fuel problem. Did you clean your carbs?
VN750 #9300 & VROC #33453
The DEUCE is offline
post #3 of 16 (permalink) Old 05-14-2012, 06:04 PM
Sounds like blocked carbs, won't tickover idle jets blocked, try carb cleaner, if you can get it running get some seafoam into it.
Swagman is offline
post #4 of 16 (permalink) Old 05-14-2012, 06:16 PM Thread Starter
thanks for the feedback...The fellow I got it from said he cleaned out carbs and it was running for abt 2k miles when he had it. He stored it for the winter and had stabil in the tank. He drove it to my house, but needed starting fluid to get it running.....I guess once you can get it running a while it can be driven. I'm not taking chances on putting it on the road until I'm confident it won't fail on me....
post #5 of 16 (permalink) Old 05-14-2012, 06:23 PM Thread Starter
thanks for feedback...Previous owner cleaned carbs with spray, and put about 2k miles on before he stored it for winter. Had stabil in tank, but needs starting fluid to get it to fire up....maybe carbs not as clean as he claims....guess I'll be trying that angle...thanks again...
post #6 of 16 (permalink) Old 05-14-2012, 06:35 PM
romeobravo172
romeobravo172's Avatar
Sounds like at the very least the idle/throttling jets are clogged,they have the tinest of holes in them to allow fuel flow. Does it run at all with choke ingaged, say half or full? Is the petcock working properly allowing fuel to carbs ? Sounds like it may be simple or more complicated! Keep watching here am sure you will find answers.
romeobravo172 is offline
post #7 of 16 (permalink) Old 05-14-2012, 07:27 PM Thread Starter
choke has no effect, cable moves ok, and linkage seems to travel to end position on handle and at other end by carb. To clean jet, carb has to come off and be disassembled right....No way to back flush is there?
post #8 of 16 (permalink) Old 05-14-2012, 07:41 PM
romeobravo172
You can try straight seafoam into the carbs, take the 2 fuel lines off petcock, the 2 pointing toward the carbs, the one coming straight up to petcock is the vacume line that lets fuel flow. Drain carbs of any fuel in bowls, there is a set screw for this on each carb, fuel will come out a little nipple, close them back and add the seafoam straight into the two fuel lines, like with a syringe or eye-dropper. Let sit like 24 hrs, drain , put fresh fuel in, I would again with syringe ect and try to start. Ck petcock that it is free flowing fuel! Pull the 2 fuel lines off petcock, pull vacume line off the front carb and introduce vacume to it, literally suck on it a little, if the petcock is ok fuel will literally flow from the 2 outlet nozzles!! Make sure PC is in the ON position!! Or RES with fuel in tank!
post #9 of 16 (permalink) Old 05-14-2012, 08:30 PM Thread Starter
thanks for the suggestions, we will try all that as soon as it stops raining here....
post #10 of 16 (permalink) Old 05-19-2012, 10:24 AM Thread Starter
Hi all......Well I can get it to start now by using no choke, then turning throttle full advance, holding a moment then let it return, while start button is pressed. When it fires, I have to advance throttle by jiggling to keep it running until it warms a bit and stabilizes....any thoughts as to what I have to do to make this beast fire up like a normal bike should lol.....thanks everyone....
