Tech/Musician/Friendly
Valve float housing?
On the rear float chamber there is the float valve that sits in its housing labeled 3.0 with the keikhin K on it. What is this part called? It feels like it is tapped into the float chamber.
This little housing piece has two holes in it. That piece on the R float chamber is positioned to where the two holes look to allow fuel through. On the F float chamber, the "float valve housing" is positioned where the two holes are blocked.
Is this a problem?
Is this a problem?
Sponsored Links | |||
What's the part number?
VN750 #9300 & VROC #33453
What are these holes for? There is no part number listed.... The piece is located where the part#16030 fits in on the float chamber and has two holes in it I assume to allow fuel to flow through.
1620-1051..Chamber float complete $158.33 cheap cycle parts.com
http://www.cheapcycleparts.com/model...rburetor-parts
Originally Posted by AudibleCreations
View Post
Why the hole is there I am not sure, unless it is helps fuel flow into the float chamber when the needle is off the seat,It has been awhile since I have been into those siamesed carbs.
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
