Just a regular guy
Seafoam
This may be a stupid question but... Should Seafoam be used on a full or empty tank? I bought a can and it doesn't specify.
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Sponsored Links | |||
their website says to use 2 oz. Sea Foam to each gallon.
Depends on why you need it. 2oz/gal for moisture control is fine.
1/2 can per tank should clean out the fuel system pretty well.
if your carbs are dirty....drain them and fill with seafoam and let sit overnight...then drain and fill cards with fuel and give it a shot.
Light Bar mounts:https://www.vn750.com/forum/showthread.php?t=23644
Turn signal light inserts LED:
https://www.vn750.com/forum/showthread.php?t=21752
https://www.vn750.com/forum/picture.p...pictureid=2537
2006 VN750
VROC # 34354
I put it in when the tank is low/empty, then add gas and let the inflow mix the stuff around.
You CAN run on straight Seafoam, but it smells awful, and might not be best for the bike...
Hippie
Hippie
2005 VN750 upwards of 14K (haven't looked lately)
Mods:
AGM Battery
Degoated
Headers wrapped
Custom paint
personally i never cares for seafoam in my cars but after hearing every body on hear talking about it i used some on black betty
added about a third of a bottle to a full tank of premium and she pops of a little white smoke when i get into the throttle but she is showing improvements so i guess it is working
Originally Posted by hot_rod_hippie
View Post
VN750 #9300 & VROC #33453
I usually put some in every few fillups when the tank is full.
1986 VN 750
20,000 miles
Replaced Stock Turn signals
Starter Clutch
NGK plugs
MT66 Pirelli's
Seafoam
Originally Posted by new rider 9984
View Post
I run Chevron brand gasoline in every thing I have. Never have had any problems with fuel related performance in anything I own. One pickup I sold latey had 429,000 miles on it and the only thing I ever did to the engine was one distributor and two water pumps. Never broke any other gasket on her. Pulled two injectors out at 350,000 miles just to check for carbon and they were as clean as new. I guess I'm suggesting that if you use a good quality fuel with a built in cleaning agent you shouldn't need to much carb maintenance.
Well, the PO of my bike left it sitting outside for about 8 months and didn't take great care of it. It has carb issues I am trying to work out. I cleaned out a clogged petcock and that worked for a few days but now I am getting the sputtering and rpm issues back. I'm hoping a couple doses of Seafoam will help.
===2001 Vn750====
Ears shaved
Sportster pipes
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
