Throttle takes a second to drop when I let off the gas - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 51 (permalink) Old 05-06-2012, 10:54 PM Thread Starter
I just re-assembled my bike. The carbs are actually a different set setup for an Earshave. They are 141/F, 142/R, 40 Pilots. Supposedly they were chem dipped prior to clean them.
Idle is also a bit rough below 1400rpm
I am thinking something is a little sticky inside the carbs. With some SeaFoam I think it will clear up.
Any thoughts?
post #2 of 51 (permalink) Old 05-06-2012, 11:07 PM
Disconnet the throttle cables at the carb. Then move the throttle linkage to full then let go, it should snap back. Then try it at different positions. If it always snap back, then one or both of the cables may be worn, or dirty. Most likely it is a cable.
Rebel13 is offline
post #3 of 51 (permalink) Old 05-06-2012, 11:22 PM Thread Starter
Prior to dis-assmbly everything was muy bueno. The throttle snaps back quickly with the cables on, and off. It couldn't hurt to lube the cables, and play with adjustments some more.
post #4 of 51 (permalink) Old 05-07-2012, 08:20 AM
check your routing, lube them up with wd-40 and re assemble. it sounds like they are binding up on you.
Harley sportster fenders
custom raked front end
custom exhaust
vn800 tank and guages
modified seat and recovered
rear frame chopped
custom wiring harness
airbox removed
hzhardy is offline
post #5 of 51 (permalink) Old 05-07-2012, 09:39 AM
SeaFoam always is a good start.
However, if the linkage is snapping back but the revs are not falling back with it, you might have a sticking diaphragm. This can be caused by improper installation, a clogged vent hole, or a tiny tear in the diaphragm itself.
Likely just a clog in the diaphragms vent hole....not sure if SeaFoam would help this.
Other cause could be a small air leak from a carb boot.
post #6 of 51 (permalink) Old 05-07-2012, 10:50 AM Thread Starter
The carb boots and cables check out, so I'll inspect the diaphragm and see what's up. Cheers
post #7 of 51 (permalink) Old 05-07-2012, 11:23 AM
Crap, I WAS in 5th gear.
Rule out what you can mechanically before removing the carbs again. Check the air cut-off valves (also knows as coasting enrichers) and passages. I have a 2001 and one of my enricher diaphragms had pinholes at 35,000 miles.
Kelly2001 is offline
post #8 of 51 (permalink) Old 05-07-2012, 12:09 PM
romeobravo172
romeobravo172's Avatar
Kelly, where are the cut off valves? aka coasting enrichers, one of my 04's does that also.
romeobravo172 is offline
post #9 of 51 (permalink) Old 05-07-2012, 12:21 PM
Coasting Enricher
They are under covers on the sides of the carbs. One of the mounting screws is used when checking float height. The are kind of expensive, so you shouldn't just replace them willy-nilly. The rubber on mine had deteriorated and the inner fabric was visible. I remember being able to access them with the carbs installed. It got to the point where I had to drag the engine down with the clutch at stoplights. I had a lot of afterfiring (in the exhaust) during deceleration too, as faulty diaphragms cause a lean mixture when letting off the throttle.
post #10 of 51 (permalink) Old 05-07-2012, 12:41 PM Thread Starter
Thanks for all the advice everyone.
I am going to try to inspect them at lunch, and steal the good diaphragm from my other set of carbs if needed. I'll update this thread with any findings.
