to shave or not to shave that is the question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-06-2012, 10:25 PM Thread Starter
i just bought this 86 vulcan 750 and it has no air filters.
the question is what would be cheaper buying new filters or just getting the stuff to shave the ears?
any pricing info would be grand
post #2 of 4 (permalink) Old 05-06-2012, 10:36 PM
MaDeInSin's Avatar
When I bought my bike I had the same issue.. I purchased the filters an then a few months later did the shave.
The thing with the shave is that you can sell your "ears" if they are in good shape and make some of your money back.
For the shave you need to by some new Jets and Shimms $30.00 bucks or so.. Coasters.. $30.00 bucks or so... and a new K&N filter.. I did a K&N under the tank filter for about $25.00..
Quick pricing and my quick thoughts because I gotta run.
Ill elaborate more tomorrow if noone else has chimed in.
Good Luck!
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #3 of 4 (permalink) Old 05-06-2012, 10:58 PM Thread Starter
do you have to make and carb adjustments after the shave?
and does anyone have a spare float assembly or a good set of carbs for sell?
and how bad would it be on the bike to ride without filters for a bit i"m not planning to but the guy before me said he never bothered to see if it even had filters on it and he had it a year
post #4 of 4 (permalink) Old 05-07-2012, 01:04 AM
Ndr
I would say don't do it. You run the risk of getting large amounts of dirt/grit into your engine which has a fairly high possibility of causing undo damage. I personally wouldn't even attempt to try starting the bike without having filters in place.
to do the ear shave you will need to remove the carbs from the engine to put in the new jets and shims. The air/fuel screw will need to be adjusted.
For the full details/procedure of the ear shave and needed parts see this thread:
https://www.vn750.com/forum/showthrea...ight=ear+shave
Ndr is offline
