Is Premium Gas Worth The Extra $? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 04-29-2012, 09:34 PM Thread Starter
The riders I've talked to are split on the issue of regular vs. premium gas, so I thought I'd ask Vulcan riders: Is it a waste of money to run higher octane gas in your bike? I've gotten everything from "you're crazy to run regular" to "I've always run regular and never had a problem," so I'd love to hear what Vulcan riders have learned. Thanks!!
Pastorkent is offline
post #2 of 21 (permalink) Old 04-29-2012, 09:48 PM
Dude, stick to regular. It is what the bike is rated for. Usually higher octanes are needed if an engine has knock issues OR the vehicle is designed to use higher octane fuels. Save the money and stick to regular.
post #3 of 21 (permalink) Old 04-29-2012, 10:57 PM
The only reason to run higher octane gas is because you HAVE to....
Got a 13.2:1 compression ratio? Premiums
likely the way to go. If your motor is not knocking/pinging or burning off your spark plugs tips, you are definitely wasting your money burning high octane fuel,and may even be damaging your motor.
Contrary to what many think, high octane does not mean higher power. In a motor that runs fine on regular gas, higher octane actually puts out less power.
Save your money.
post #4 of 21 (permalink) Old 05-02-2012, 08:04 PM
RxRC's Avatar
True.
"Giving the Ralph to the prairie scrub of Grand Forks is like dressing up drunken monkeys in snowmobile jackets and packing them into the Ordway....."
RxRC is offline
post #5 of 21 (permalink) Old 05-02-2012, 08:31 PM
2000 VN 750 Senior Member
The motor was originally engineered to run on regular. Unless you did major changes to the engine you really need to stay with regular. Why were you interested in switching? If others want to pay a higher price for fuel when it is not needed then that is their choice. Do the right thing and feed your bike what it requires.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #6 of 21 (permalink) Old 05-02-2012, 10:55 PM
No. +100 to all the above. But do run a bit of Seafoam in her every now and then.
MCCT Mod
Pickup Mod
12 Volt Receptacle Mod
Memphis Shades Santa Cruz
Homemade Luggage Rack
NGK Iridium IX Spark Plugs
Harley Sportster Exhausts
Rotating/Flashing Tail Lights
170/80 Michelin Commander II
Saddlemen Highwayman Slant Jumbo Saddlebags
Bought 09/10 12.2k miles - 04/12 33.4k miles
CW-4 is offline
post #7 of 21 (permalink) Old 05-03-2012, 12:00 AM
If only it had 6th gear..
DavesVulster's Avatar
Yup Seafoam. Not just for marine use. Good stuff.
Dave
Mods:
Jetted, shaved & coastered
LED tail/plate lights
Added stuff:
Chrome levers
Hellcat windscreen
LED running lights
Home made 'Vita-Volt' meter
Foot rests on engine guard
Tunes
DavesVulster is offline
post #8 of 21 (permalink) Old 05-03-2012, 02:14 PM Thread Starter
Thanks!
Thank you for the good advice!
post #9 of 21 (permalink) Old 05-03-2012, 06:05 PM
Crap, I WAS in 5th gear.
Not mentioned in this thread yet: higher octane fuel can cause hard starting.
Two reasons for power loss are that higher octane fuels have less energy, and the engine is timed for regular.
Kelly2001 is offline
post #10 of 21 (permalink) Old 05-03-2012, 07:53 PM
I don`t know if higher octane gas has less energy, but it is harder to ignite. That is why it is used in high compession engines, to prevent pre-ignition or "engine knock" before the spark plug fires.
The vn750 engine`s compession ratio is 10.3:1. From my experience with small block Chevys over 35 or 40 years, I would have thought that was high enough to use higher octane fuel too, until I read in the service manual and on this board that regular 87 octane is all this engine requires.
My friend has a 2005 Harley Electro-Glide whose engine is lower compression, about 9.5:1, IIRC. The H-D Motor Company recommends high octane fuel for that engine, and my friend says it does run better and has more power with it than on regular when he can`t find the high octane juice.
The only explanation I can think of is that the Vulcan may have a higher connecting rod to stroke length ratio. There was an article in an old hot rod magazine about 15 or 20 years ago that was called "The 350 that Chevy Should Have Built". To make a long story short, a stock 350 ci has connecting rods 5.7" long and a stroke of 3.48". The engine these guys built had connecting rods ~6.2" long and a 327 crankshaft with a stroke of 3.25". The longer con rod/stroke ratio means the connection at the piston wrist pin has narrower angle of movement during rotation of the crankshaft. This leads to the piston sitting at TDC (top dead center) for a fraction of a second longer on each stroke. I do not remember the whole explanation of why this allows a engine with a compression ratio in excess of 10:1 to run on 87 octane, but it does. This engine was making about 200 ft lb of torque at 2500 rpm and 400 ft lb at ~5600 rpm. Nothing to sneeze at, all things considered.
So as I said before, maybe the rod length/stroke ratio may be why the vn engine runs so well on regular gas.
