Carb Clean Solvent?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-28-2012, 04:38 PM Thread Starter
About to attempt my first carb clean and wondering what kind of solvent you use to soak and clean the parts? The Clymer's Manual does not recommend standard carb-cleaner, but does recommend a petroleum based solvent. Got any rec's on a petroleum based solvent for cleaning my carbs?
Thanks!
BikeWheel is offline
post #2 of 5 (permalink) Old 04-28-2012, 05:10 PM
I use Berryman's Chem Dip for submerging parts. And then fallow up with a couple of cans of NAPA brand carb cleaner.
post #3 of 5 (permalink) Old 04-28-2012, 06:29 PM
MaDeInSin's Avatar
When I do mine.. I have a gallon of GUNK carb cleaner that works great... it even has a basket to submerge the smaller parts.
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #4 of 5 (permalink) Old 04-29-2012, 11:54 PM
Dar_le's Avatar
Just pulled mine today, Gunk seems to work well and i love the little basket
Dar_le is offline
post #5 of 5 (permalink) Old 06-08-2012, 03:58 PM Thread Starter
Wow, life got in the way so sorry for the delayed response. I ended up going with Berryman's chem dip which also has a dip basket because of the reviews on Amazon between GUNK and this product, Berryman won out. Thanks so much for the response. And not to crack her open!!!
