not starting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-28-2012, 01:20 PM Thread Starter
not starting
Cleaned the carbs and now the bike will not start. She turns over, has spark and it just doesn't want to start. I need help. Hoses all hooked up. She is getting fuel. She will try to start but nothing. Replaced spark plugs and air filter.
thefrenchfrog is offline
post #2 of 4 (permalink) Old 04-28-2012, 01:53 PM
Originally Posted by thefrenchfrog View Post
Cleaned the carnal and now the bike will not start. She turns over, has spark and it just doesn't want to start. I need help
carnal??? Do you means carbs?
Are all the hoses hooked up in the right place?
Vacuum hose to petcock?
Need more info.
Will it fire off with a little starting fluid sprayed on the foam air filter?
post #3 of 4 (permalink) Old 04-28-2012, 08:06 PM
JM2001's Avatar
Is your engine kill switch on RUN ? If you have spark,fuel, and I assume air, it should fire.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 4 (permalink) Old 04-30-2012, 09:25 PM Thread Starter
Well I adjusted the air/fuel mix and she fired right up
