ok what's the trick - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-24-2012, 09:52 PM Thread Starter
ok what's the trick
I have gotten my carbs totally clean and put back together except I am stuck with a spring that I can't get back on. I am not sure what this gadget does but it is at the top of the carb and there is one like it on the rear carb linked by a rod to the other one.
There is only one spring on it and it is on the front carb. I can't get that spring on correctly.
Please tell me how this is done and if you can send a picture the way it looks will help a lot.
Blessings!
Rich
mrseedsower is offline
post #2 of 4 (permalink) Old 04-25-2012, 12:58 AM
That's the choke leankage you need the spring and don't feel bad I had the same problem you just have to play with it till its right sorry I have no pic maybe some one will chime in with som
TheEDGE is offline
post #3 of 4 (permalink) Old 04-25-2012, 08:22 PM
Ccrobins has a whole scwhack (technical term ) of carb pics here in the gallery:
https://www.vn750.com/photopost/showg...puser=962&sl=c
Maybe you can find a picture in there that will help you.
post #4 of 4 (permalink) Old 04-25-2012, 09:01 PM
good idea Hoss
Cut & paste from crobins....
VoIPDoc is offline
