grinding noise on decel - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 04-23-2012, 11:27 PM Thread Starter
Not sure exactly where its coming from, but when i ride i can hear a ginding-ish noise when i apply throttle. when i release throttle it goes away. im not even sure where to start. i looked up the coffee grinder noise, but it says that goes away once engine is warmed up. i was still hearing this after a half an hour ride with warm up. not sure it happens at full throttle due to loud pipes. cant hear it because of those at higher rpms. Also i am getting lower gas mileage around 40mpgs. I have recently put in iridiums and switched to mccts. trying to give enough background as i see needed. Thanks for all the help Mick.
Mick51 is offline
post #2 of 9 (permalink) Old 04-24-2012, 05:35 AM
do you hear it at idle? is it coming from the engine, or that back of the bike? A member once posted with a similar noise coming from the right side of the bike, and he traced it to the little loop shaped heat shield... the rivet had broken.
post #3 of 9 (permalink) Old 04-24-2012, 07:11 AM
Ndr
Have you checked the final drive splines? Not sure if the sound fits with normal symptoms of the drive shaft being damage, but its certainly worth a look.
Ndr is offline
post #4 of 9 (permalink) Old 04-24-2012, 10:25 PM Thread Starter
Took it for another ride today. I couldnt hear it at idle but it was there again while riding. It sounds like it is coming from beloe the tank. I looked around and didnt see anything loose. I havent checked the splines, but it doesnt seem like that to me. Thanks Mick.
Mick51 is offline
post #5 of 9 (permalink) Old 04-24-2012, 11:22 PM
I'd check the splines, just in case. You don't want to end up stranded and looking for a $200+ part on eBay.
post #6 of 9 (permalink) Old 04-25-2012, 10:39 AM
flitecontrol's Avatar
How old is your bike? Some of the early models, especially if they sat for a while, have the balance rubbers disentigrate. If it goes too long, the balancer comes out through the lower left crankcase. See project bike notes in my sig.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 9 (permalink) Old 04-25-2012, 10:54 AM
Just to add some notes to this. When you see the dampers begin to disintegrate, you'll notice black plastic flecks on your oil screen. Also, it can cause a 'knock' noise at idle.
Requires an engine tilt/pull. They're behind the rotor which is behind the stator.
post #8 of 9 (permalink) Old 04-25-2012, 03:50 PM Thread Starter
Its an 85, so it doesnt get any older than that for our bikes. Is the only way to check them by looking for plastic in the oil or is there another way. Also whats a ballpark for skill and money needed to do this. Thanks Mick.
Mick51 is offline
post #9 of 9 (permalink) Old 04-25-2012, 07:38 PM
Here is a picture in the gallery of the balancer gear chewing into the case:
https://www.vn750.com/photopost/showp...to=294&cat=505
