Carb sync WAY out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-23-2012, 03:42 PM Thread Starter
Carb sync WAY out
As I just bought this bike, I decided to check out some stuff. Built a carb balance tool for $15 and set out to hooking it up. To my surprise, the bike just wanted to suck all my oil out of one of the hoses! I hooked it up the opposite way but still the same result (so I knew my tool was good).
The result: about 5 turns increasing the rear cyl vacuum before it was dead on.
Anyone ever heard of carbs being that far out of sync? Should it have even ran? I rode it before that and it didn't seem like anything was that far out of whack. I did notice that the throttle wasn't as snappy as I would imagine, but still. No incredible lag or anything like that.
Nebraska68 is offline
post #2 of 3 (permalink) Old 04-23-2012, 04:18 PM
4getful2's Avatar
That's quite a bit out. You might want to run a couple tanks with some some seafoam in it and recheck.
Like buying anything else used, you never really know what to expect.
4getful2 is offline
post #3 of 3 (permalink) Old 04-23-2012, 05:04 PM
Synching CV carbs only effects idle. So would not effect the throttle.
Good suggestion to clean the carbs out and sync again, a dirty jet can make a huge difference when intake is that low.
