Jets clogged help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-20-2012, 10:03 PM Thread Starter
Jets clogged help
On the secondary jet, the long one, it is clogged. Since I haven't seen this jet open. Is the hole from the bottom the same all the way through or does it narrow from the slick part to the threaded part?
If I can't get this unclogged, I wanted to run a small drill bit by hand thorugh it to unclog it. Any one know?
Blessings!
Rich
mrseedsower is offline
post #2 of 4 (permalink) Old 04-21-2012, 12:33 AM
you should be fine.. or use a guitar string
post #3 of 4 (permalink) Old 04-21-2012, 08:45 AM
flitecontrol's Avatar
Have you tried carb cleaning solution? Do you have access to a sonic cleaner? If you change the size of the hole in the jet, it will affect how the bike runs.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 4 (permalink) Old 04-21-2012, 07:35 PM
Blessings!
Rich
I saw a picture of someone using a set of oxyacetylene welding tip cleaning tools on a carb jet a day or so ago.
Just another option, and less chance of scratching the brass jets.
