Fuel Cap / Key Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 04-12-2012, 10:08 PM Thread Starter
I'm trying to open the cap on my tank. Since I have had the bike I have yet to open it. On every other bike I have had, the key goes all the way in and then you turn. This one I am confused or have a blocked keyway? As seen in pic, this is far as the key can go in and farthest to the right it goes is to the dot on right. I would assume normally it would go all the way in and turn just past the arrow on the right. Is there possibly a broken key in it or is the retracting arms on the cap ceased or both? I already fractured the original key I was given trying to open, and it also wasn't that strong. I don't want to brake more keys. How can I open it? Thanks!
Rebel13 is offline
post #2 of 23 (permalink) Old 04-12-2012, 10:20 PM
romeobravo172
romeobravo172's Avatar
Try pressing down on the cap as you slowly turn to the right, could spray a little wd40 in the keyway too, my key does not go all the way in either.
romeobravo172 is offline
post #3 of 23 (permalink) Old 04-12-2012, 10:37 PM Thread Starter
That's good to know. I doused it with wd-40 and worked the mechanism a week ago. I will play with it more over the weekend.
Rebel13 is offline
post #4 of 23 (permalink) Old 04-12-2012, 10:41 PM
romeobravo172
Are you sure it is correct key?
post #5 of 23 (permalink) Old 04-12-2012, 11:19 PM Thread Starter
I'm pretty sure. It is the ignition key, the cargo key/helmet lock key doesn't turn it at all.
Rebel13 is offline
post #6 of 23 (permalink) Old 04-12-2012, 11:35 PM
romeobravo172
Locks get changed a lot,or tumblers. I think normally the ignition, fuel cap, and helmet key is the same, tool box different, or at least on my 04 was like that. Took me about 3 minutes to alter that cylinder so now 1 key fits all 5.
post #7 of 23 (permalink) Old 04-12-2012, 11:44 PM Thread Starter
That's true, it is possible. I have many other things to do to the bike this weekend. In between things I will try working it some, if I don't free it I will take it to the locksmith.
Rebel13 is offline
post #8 of 23 (permalink) Old 04-13-2012, 01:07 AM
Patriot Guard Rider
The DEUCE's Avatar
I had the same issue and couldn't get it to work. I had to beat a screwdriver in the key slot and turn. I eventually purchased a new lock.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #9 of 23 (permalink) Old 04-13-2012, 04:52 AM
all the lock cylinders are supposed to be keyed a like from the factory... as far as the sticking gas cap key... it looks like you need to take it apart and lube/clean the tumblers, and reassemble with the key in.. or get a new lock.
post #10 of 23 (permalink) Old 04-14-2012, 01:51 PM
I have an 86 model and one key fits all the locks, looks like your locks are all different
Swagman is offline
