Bobber Chopper VN750
how does choke system work?
I bought my vn750, 1986 not running.
carbs are rebuilt, ears and coasters done.
there is a loose hanging cable from the choke enrichment plungers.
I read the loose position is choked on-right?
sounds backwards to me.
should those two plungers be held up when running normal?
thanks!
thanks!
Sponsored Links | |||
the enrichment plungers will be pulled in the up position for the choke to be on and down for normal running
96 750 vulcanlittle red bewitch
12561 miles
r/r relocated
leathersaddle bags(take on/ off)
memphis slim windshield (depends on mood)
p/u coils set at .020
agm battery , flame embossed seat cover
drilled clutch hub(3-20-12)
stainless steel coasters (3-28-12)
toc mccts installed(4/3/13)also changed to led bulbs in tail lamp
k&n air filters (4/20/13)
iridium plugs(4/20/13) along with ngk plug caps
V&H pipes, crash bars , luggage rack 4/5/2014
that cable can be a bear to get hooked up
12561 miles
r/r relocated
thanks, Dude. that makes sense!
glad to help, hope that dose the trick
12561 miles
r/r relocated
Sponsored Links | |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
