Stalling issue when putting into gear - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-21-2012, 07:57 PM Thread Starter
Captive New Yorker....
peterherrm's Avatar
My bike starts fine, idles great. When I go to release the clutch, once I get over half way, it's like something is grabbing the engine and keeping it from running. If I squeeze the clutch in it springs back to life. Occasionally it will backfire.
It did this a few days ago, then stopped doing it and it ran fine with the clutch fully released until I got it up to about 40mph, the it starts loosing power. But today it will not let me fully get it in gear at all without stalling out once the clutched is released passed the halfway point. It doesn't just cut out like it would if the stand switch cut power, the rpms get very low and it acts like it being chocked to death. I'm guessing a carb problem?
Would appreciate any help......
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #2 of 7 (permalink) Old 03-21-2012, 07:59 PM Thread Starter
peterherrm's Avatar
Just an addition to above. It did this same thing in the fall also, but very intermittently. It would be find one day, then the next day start with this again.....
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #3 of 7 (permalink) Old 03-21-2012, 08:55 PM
Patriot Guard Rider
The DEUCE's Avatar
Is your side kick stand all the up? If so, maybe it's going bad.
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 7 (permalink) Old 03-21-2012, 08:57 PM Thread Starter
peterherrm's Avatar
Yeah, and I pulled out on the plunger just to be sure. Could a faulty side stand switch even cause something like this?!
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #5 of 7 (permalink) Old 03-21-2012, 09:18 PM
MaDeInSin's Avatar
I had the same issue and it was my kickstand switch.. I was able to just pull mine out and hit it with some WD40 to loosen it up again..
Goodluck with it!
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #6 of 7 (permalink) Old 03-21-2012, 10:36 PM Thread Starter
peterherrm's Avatar
It was the side stand switch! I cut the outer tube holding the wires and water came pouring out. Removed the switch, and it now runs perfect. Thanks for the help!!
Pete Herrmann
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
post #7 of 7 (permalink) Old 03-22-2012, 01:13 AM
Mine wasn't hooked up when I got my bike, that's one pain I didn't have to deal with.
shark88 is online now
