Backfire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-19-2012, 11:55 PM Thread Starter
hbhobby's Avatar
Backfire
Whenever I let off the throttle I get backfire or at least popin'. It's not as bad after it's warmed up but it never completely stops. I've ran a can of Sea Foam through it and didn't help.
Any ideas where I need to start?
hbhobby is offline
post #2 of 10 (permalink) Old 03-19-2012, 11:58 PM
Have you backed out the idle adjust screws to 2-2.5 turns out (total)?
post #3 of 10 (permalink) Old 03-20-2012, 12:42 AM
MaDeInSin's Avatar
Search Coasters or Marbling in the versus. Either of these options may help reduce the backfire. I did a complete "earshave" and that helped to greatly reduce mine.. You can also check for leaks in the exhaust system.. Use a cigarette and follow your exhaust and see if the smoke is disturbed. Could need to replace the crush gaskets.
X2 on the idle adjust screw on the side thats popping..
goodluck!
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #4 of 10 (permalink) Old 03-20-2012, 05:00 PM
There is nothing wrong with the bike. It is mostly just annoying. Most of us take measures to reduce or totally eliminate the popping by doing as described above. But if you can live with it, leave it alone.
post #5 of 10 (permalink) Old 03-20-2012, 07:13 PM
Crap, I WAS in 5th gear.
If marbling or coastering doesn't help, report back as the group has been through this before, many times.
Kelly2001 is offline
post #6 of 10 (permalink) Old 03-22-2012, 12:04 AM Thread Starter
hbhobby's Avatar
Thanks guys. I messed with the idle screw. It seemed like it was more than 2.5 turns. I warmed it up and tweaked it a little more. The popping is not as bad.
hbhobby is offline
post #7 of 10 (permalink) Old 03-22-2012, 04:48 PM
fergy's Avatar
Actually it isn't the idle adjust screw you need to adjust, but the idle mix screws or pilot jets, one on each side of the bike, often still covered with a tin cap that you have to pry off before you can get to them. The 750's are known poppers and usually you can marble the reed valves and quiet the bike down considerably. I did this alone to mine and never touched the idle mix screws and got rid of the really loud popping on decel. Your mileage may vary...
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #8 of 10 (permalink) Old 03-22-2012, 05:58 PM
My Canadian bike never had any of the emission crap on it and had coasters installed at the factory. It still pops loudly upon deceleration.
If it bothers me when I finally get to ride again in a few weeks, I will turn the idle mix screws out a bit.
post #9 of 10 (permalink) Old 03-22-2012, 06:05 PM
My UK bike is the same OlHoss
Swagman is offline
post #10 of 10 (permalink) Old 03-22-2012, 08:47 PM
Those are what I was referring to above.
The usual fare is to back them out 2 - 2.5 turns, depending on side.
