Small leak - old fuel line? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-13-2012, 09:58 PM Thread Starter
I noticed a small gas leak pooling in the V section of the engine, and finally have traced down where it originated from (at least, from what I can tell).
The leak only would happen if I have a decent amount of gas in the tank. Anything below half and it doesn't do it. The fuel line is probably quite old, judging by the picture. I have new fuel line ready to throw on when I perform the balance damper install.
I noticed the leak was a little bit dark, as if there was a tad bit of oil in it. I wonder if this is a sign of anything else, or just the old fuel line needing replacement?
Here is a image of the fuel line connection in question, its LH side in the middle of the carbs.
post #2 of 15 (permalink) Old 03-14-2012, 10:30 PM
Looks like that crappy plastic fitting to me...you can get a solid brass replacement from Harley for it....just tell them its for a Keihin carb...some Harleys used Keihins....
post #3 of 15 (permalink) Old 03-14-2012, 10:36 PM Thread Starter
Sweet deal.
I'd hope it would be easy to install, without a carb removal anyways. I may completely pull the engine when I do my dampers, so I'll have decent access.
post #4 of 15 (permalink) Old 03-14-2012, 10:36 PM
bow_dude's Avatar
Send a message via Yahoo to bow_dude
noticed theoil and stuff on the screw above it may be leaking at the seal for carb bowl
little red bewitch
96 750 vulcanlittle red bewitch
12561 miles
r/r relocated
leathersaddle bags(take on/ off)
memphis slim windshield (depends on mood)
p/u coils set at .020
agm battery , flame embossed seat cover
drilled clutch hub(3-20-12)
stainless steel coasters (3-28-12)
toc mccts installed(4/3/13)also changed to led bulbs in tail lamp
k&n air filters (4/20/13)
iridium plugs(4/20/13) along with ngk plug caps
V&H pipes, crash bars , luggage rack 4/5/2014
bow_dude is offline
post #5 of 15 (permalink) Old 03-14-2012, 10:38 PM
bow_dude's Avatar
if it is the crappie fitting i bought one for $11 at harley dealer brass not plastic
little red bewitch
12561 miles
r/r relocated
bow_dude is offline
post #6 of 15 (permalink) Old 03-14-2012, 10:49 PM Thread Starter
Thanks for the info all around. I may go ahead and replace the fitting with a brass one anyways; no need to have nearly 25 year old plastic being in control of my fuel.
The only ones I can find online are around $40 out the door. Worth it, but I'll check locally first. (Example)
post #7 of 15 (permalink) Old 03-14-2012, 10:51 PM
Link to old hippies carb inlet replacement with a brass fitting:
https://www.vn750.com/forum/showthread.php?t=19832
Wolfie provides a source for a press in fitting in post 9:
http://www.cv-performance.com/cvp-fuel-max-inlet-elbow/
post #8 of 15 (permalink) Old 03-14-2012, 10:56 PM Thread Starter
Amazingly Awesome.
Thank you everyone x2.
post #9 of 15 (permalink) Old 03-15-2012, 04:01 AM Thread Starter
Two of those bad boys ordered from CV Performance.
post #10 of 15 (permalink) Old 03-15-2012, 10:00 PM
bow_dude's Avatar
:smileycheck at harley dealer its part #27371-76a Ll-joint fuel inlet ( made in japan) lol
little red bewitch
12561 miles
r/r relocated
bow_dude is offline
