High winds cause the motor to die - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-07-2012, 11:30 AM Thread Starter
14sec vulcan
I rode my bike to work yesterday and it did perfect but when I left there was a 40-50 m.p.h cross wind, while doing 45 mph every time I got a gust of wind the engine would fall on its face and would almost die. I have never heard of a problem before so any input would be great because it has me stumped.
14 sec 750 is offline
post #2 of 16 (permalink) Old 03-07-2012, 11:43 AM
Sounds like the wind blowing into your carb breather vent, have you done the earshave if so where have you put the carb breather pipe, if not the breather in the right side air filter is it located properly in the rear of the filter housing
Swagman is offline
post #3 of 16 (permalink) Old 03-07-2012, 11:50 AM
JM2001's Avatar
x2 Sounds like the carb vent hose is not pushed into the backside of the right ear. There is a square slot for it to be pushed into. Cut the tip of the hose at about 45 degrees angle before pushing it in.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 16 (permalink) Old 03-07-2012, 11:58 AM
The vent pipe pushes into a round slotted hole at the side of the square hole well it does on my filter case unless different to a USA model
Swagman is offline
post #5 of 16 (permalink) Old 03-07-2012, 12:04 PM
JM2001's Avatar
You may be right. I'm having a brain cramp this morning. You are right. Round slotted hole
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 16 (permalink) Old 03-07-2012, 12:10 PM
JM2001's Avatar
Check out post 13 of this thread for picture
https://www.vn750.com/forum/showthrea...nt+slot&page=2
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #7 of 16 (permalink) Old 03-07-2012, 12:36 PM
Never mind JM2001 I'm like that everyday think its my age don't know about you
Swagman is offline
post #8 of 16 (permalink) Old 03-07-2012, 05:52 PM Thread Starter
14sec vulcan
I have not done the earshave but I did replace the filters so maybe I didnt get it put back.
post #9 of 16 (permalink) Old 03-07-2012, 05:54 PM Thread Starter
14sec vulcan
Thanks for the info everyone im gonna check it out
post #10 of 16 (permalink) Old 03-07-2012, 06:04 PM
No problem hope it works out ok
Swagman is offline
