Carb Drain Screw - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-07-2012, 09:45 AM Thread Starter
Quicksilver3602's Avatar
Cool Carb Drain Screw
I have a stripped carb drain screw part number 92009-1095. I was wondering if it was possible to replace this with a more durable screw. It seems really soft, and on the right side its difficult to get the drain screw out, so easily stripped.
http://www.ronayers.com/ProductDetai...87/SKU/1079001
Ref #: 92009
Part #: 92009-1432 (92009-1095)
Screw, Drain, M6x1.0 1 per carb.
ID:	4318   Click image for larger version
2003 VN750
Deka MF Battery
Cleaned and Rebuilt Carbs Multiple Times
NGK Iridium Plugs
New Plug Wires
New Petcock w/screens
Fuel Tank Rust Removal - The Works Method
ACCT to MCCT Conversion
Brake Fluid Flush - Nice and Firm now
The List
Spline Lube
Fork Seals/Dust Caps
New Front Tire
HID Headlight Kit
Quicksilver3602 is offline
post #2 of 6 (permalink) Old 03-07-2012, 12:38 PM
Crap, I WAS in 5th gear.
Don't know of a replcement screw that might work- it's a special application. You could try slotting the head with a dremel cut-off wheel and using a screwdriver. Also, don't overtighten!
Kelly2001 is offline
post #3 of 6 (permalink) Old 03-07-2012, 12:47 PM
On my Vulcan, you don't have to take the screw out to drain the carb. It also is a slotted screw. Seems they changed them at some point.
Don't know if the newer slotted screws fit the older bikes though....
post #4 of 6 (permalink) Old 03-07-2012, 12:49 PM
x2 that would be the easiest option if only the head is damaged
Swagman is offline
post #5 of 6 (permalink) Old 03-07-2012, 01:15 PM
rev it up's Avatar
hmmm,mine is the same as KM,no need to remove it. Sloted head on it,half turn and it drains carb. I thought they would be all the same,,Oh,and mine aint made of brass,thats very soft stuff is brass thread.
AGEING IS INEVITABLE,,MATURING IS OPTIONAL
VN 750 A8 1992.
27000 miles.
Imported from California
to UK in 1996.
New for 2012.
new filters(foam type)
replacement shocks(MDI)
Iridium plugs.
AGM battery(platinum)
brake pads(Kyoto)
(All on and running)
rev it up is offline
post #6 of 6 (permalink) Old 03-07-2012, 01:56 PM Thread Starter
Yeah called the stealership....they want $12 a piece......yikes.....Will hit it a few times with a hack saw or dremel.....Thanks for the advise.
2003 VN750
Deka MF Battery
NGK Iridium Plugs
New Plug Wires
The List
Spline Lube
New Front Tire
HID Headlight Kit
Tags
carb
