Cleaned Carbs & Earshaved - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 03-04-2012, 06:01 PM Thread Starter
MaDeInSin's Avatar
Hey All-
I am sooooo close to being done with my earshave but I am missing a couple of parts for my carb before I can reassemble. I need to know if there is any temporary substitute for a couple of things until the OEM parts get here from kawasaki.. I would like to fire this baby up today... Heres what I am missing
I had 2 shims.. I needed (4).. I have 4mm flat washers... will that work? Any other ideas?
On my Pilot screw I am missing the washer and the O Ring.
Any ideas what would work for now?
Thanks All
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #2 of 2 (permalink) Old 03-05-2012, 10:08 AM
As long as the shims are the same thicknes as your washers then it would be the same ratio. I do not know how thick the shims are though.
