Still pulling carbs - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-03-2012, 03:07 PM Thread Starter
Still pulling carbs
I found the leak to my front carb. The front boot is disconnected. I have the carb disconnected on both boots with the rear one disconnected at the cylinder and the front one disconnected at the carb. Except the whole boot is disconnected before I touched it. I still can't get the carbs to come out.
Do I twist them out or hit them with a big hammer? Any suggestions?
Blessings!
Rich
mrseedsower is offline
post #2 of 4 (permalink) Old 03-03-2012, 03:16 PM Thread Starter
How do you get the duct tubes out of the way? If I pull them loose from that surge tank how will ever get them back on? I now see why the ear shaving is a way to go.
post #3 of 4 (permalink) Old 03-03-2012, 04:26 PM
Pull them out and when you put them back use some lube wd40 or something and push them in with a blunt instument you dont want to put a hole in them
Swagman is offline
post #4 of 4 (permalink) Old 03-03-2012, 10:34 PM
If yall don't mind I want to jum in here just got my carbs off and apart the slide or vacume diaframs are ripped if you run into this problem get ready no one makes a kit for the carbs but to jet them I had to order each individual pease to a total of 350.10 to fix my carbs myself not complaning bout the work love that but why can't some one make an afordable kit
TheEDGE is offline
