gas lines - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 03-03-2012, 01:46 PM Thread Starter
gas lines
When we got this bike the tank was disconnected from the carb tubes. On the petcock there is two outlets that are the same size and then under the tank more there is a smaller outlet that is attached to the petcock. Where do the carb lines goes? I am assuming on the matching set of outlets. Then what is the smaller one for?
Blessings!
Rich
mrseedsower is offline
post #2 of 8 (permalink) Old 03-03-2012, 01:56 PM Thread Starter
nevermind I figured it out. The float must be stuck as the gas goes straight through the carbs and drains out a boot. Got to pull them to find the problem.
post #3 of 8 (permalink) Old 03-03-2012, 02:01 PM
romeobravo172
romeobravo172's Avatar
Try the Seafoam in carbs first before pulling. Might fix prob. The third line is the vacume to let fuel flow out the 2 fuel lines. That line is attached to the front carb or left side.
romeobravo172 is offline
post #4 of 8 (permalink) Old 03-03-2012, 02:43 PM Thread Starter
there is something that either the boot is bad going to the front head and or the float is stuck open. Gas just poured out the bottom of the front carb.
post #5 of 8 (permalink) Old 03-03-2012, 02:49 PM
Most likely a sticking float try tapping the side of the float bowl with the head of a screwdriver, the seafoam may loosen off crud that is holding the needle valve open
Swagman is offline
post #6 of 8 (permalink) Old 03-03-2012, 02:58 PM
flitecontrol's Avatar
The petcock shouldn't allow fuel to pass unless the engine is turning over. If it's leaking a long time after the engine is off you have two problems. A bad petcock and faulty float valve.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 8 (permalink) Old 03-03-2012, 03:10 PM Thread Starter
Swagman, I have used seafoam on my other bikes and it works great even when the Honda service tech said there wasn't anything else that could be done to those old carbs so he suggested I buy a new bike.
Anyway, what I learned about seafoam is that I need filters inline due to the settlement in the bottom of the tank could clog my jets. Since my front boot is completely disconnected I need to pull the carbs to fix that as I can't get my hands in there.
post #8 of 8 (permalink) Old 03-03-2012, 04:32 PM
Well if they have to come out then give them a good service while they are out mine had blocked idle jets took me a while to get them clean the bike had been stood since 1998 so it was pretty dirty in the carbs but they are fine now its a wee bit fiddly but take your time and they do come out and go in just have to get them in the right position, and when you put them back make sure you have the rubber boots in the right place check the manual for the position
Swagman is offline
