Gas Gauge - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 02-29-2012, 10:14 AM Thread Starter
Question Gas Gauge
I own a 1990 750 Vulacn 17,788 and still counting. My gas gauge is not working. All of my other gauges work execpt the fuel gauge. I have been resesting the trip omedeter to detrmine when I have to fill up, and I'm getting tired of that.
What can cause it not to work it just shows empty.
I have looked online and at my local stores for just a brand new gauge system, but I cant seem to find none either.
Please I would appreiacte if i could get some helpful feedback - I don't wanna brake down anymore. Especially for a dumb reason like no gas
Thank's
post #2 of 22 (permalink) Old 02-29-2012, 10:19 AM
flitecontrol's Avatar
have you checked to be sure the wires from the fuel sensor are plugged in and there's no corrosion on the contacts?
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #3 of 22 (permalink) Old 02-29-2012, 10:25 AM Thread Starter
Question
Yes and No I looked over the whole bike every things looks good to me but I'm not to for sure where the fuel sensor is - I'm trying to get my hands on a manual so I can figure this out. I was browsing on here and found that it might be under the seat but I;m not sure?
post #4 of 22 (permalink) Old 02-29-2012, 10:29 AM
Check the wiring connector under the seat near the back of the tank, check the sender unit underneath the tank.
Swagman is offline
post #5 of 22 (permalink) Old 02-29-2012, 11:21 AM
Joem's Avatar
When you pull the seat is it a approx 1/2" square plastic plug, probably over to the left side pretty close to the tank. On mine the plug has become a bit loose from all of the times I have removed the tank. I finally had to tape it closed because it kept vibrating apart.
Joe McAdoo
Springfield, MO
[email protected]
VROC # 28175
Joem is offline
post #6 of 22 (permalink) Old 02-29-2012, 12:04 PM
fuel guage
It is not likely the actual gauge being defective. Likely the connector or wiring, I needed to replace the sender in the tank. I've read on this forum some are able to solder repair the sending unit.
good Luck
WilliamTech
post #7 of 22 (permalink) Old 02-29-2012, 01:01 PM
Are you familiar on how "reserve" works?
Not all bikes even have fuel gauges, if you run out of gas don't blame the bike.
As mentioned, check to connection under the seat. Someone here can tell you how to check the sending unit in the tank (where else would it be?) with a multitester to see if it's bad.
Not sure about the availability of a new one however if it needs to be replaced.
post #8 of 22 (permalink) Old 02-29-2012, 01:43 PM
Ceal's Avatar
The ohm range of the meter is in the manual... can't remember what the values are though.
Mine is shot. Took it out and one look at it told me it's the unit itself and not the wiring. It didn't even have a float on it anymore lol.
Even without the ohm range from the manual you can just take it out and look at it and if everything looks fine, just test it and it should give you a smooth increase/decrease in resistance.
There's a downloadable manual on here, I just don't have the link.
Also, yes, that's what reserve is there for... so you don't run out of fuel. Put it on "on" and when the bike starts acting like it's out of gas, pull to the side, put it on "res" and head to the nearest gas station, then switch it back to "on"after the fill up. Easy.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #9 of 22 (permalink) Old 02-29-2012, 02:59 PM
You can find a down loadable version of the manual in my signature.
Also, the plug may be under your tank at the edge there the mounting bolt is, under your seat. That's where mine is. I don't remember if it was always there or if I rerouted it. Either way, if it's not connected or a bad contact your guage will read empty.
post #10 of 22 (permalink) Old 02-29-2012, 04:55 PM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
X2 on all above. The sending unit with the float is accessed from the bottom of the gas tank. I had a very very small wire on the sending unit that came loose ( solder was bad ) but once i fixed that gas gauge worked great. CAUTION: If you remove the whole sending unit from the bottom side of the gas tank, be sure to put a line up mark on the unit and the tank when you remove it. The sending unit can fit back into the tank in two (2) different ways. Only one way is right!
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
